I have Created simple array of Cylinders and Cube, and I want to use array of Cylinders to cut holes into Cube.
It fails. Instead cutting holes both objects vanish. This is not first time I have this issue. It started with upgrade to 0.19.
It seems bug to me but I would like to check with others before reporting.
Here is file that fails to me:
OS: Windows 8.1 (6.3)
Version: 0.19.22284 (Git)
Python version: 3.8.5
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Possible bug: Cutting array of cylinders into cube fails
Re: Possible bug: Cutting array of cylinders into cube fails
It works if you use a normal array instead of a link array. Although it works, there is some danger in your model: boolean operations such as cut tend to fail if coplanar faces are involved. You can eliminate this by makeing the cylinders slightly bigger.
When you perform boolean operations it is usually better to use the regular array instead of the Link array; uncheck the Link checkbox in the task panel when launching Draft OrthoArray.
It is not entirely clear to me if the Link array can be used perfectly in boolean operations, or whether there is a pending commit that fixes some issues with this. Does the Link array provide a compound of the duplicated Shapes, just like the regular array?realthunder wrote: ping
This is the message that I get when using a link array as cutting tool. The Part Cut is correctly produced but I get this message.
17:16:50 <Gui> Document.cpp(818): Memory exception in holes#Cut thrown: Not enough memory available
OS: Ubuntu 18.04.5 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.22366 (Git)
Hash: 34c11fcc63efa2fc72cbc74c75c76e9f19d5c84c
Python version: 3.6.9
Qt version: 5.9.5
It works when I create array with Link array unchecked. However, that is checked by default, so if it does not work it should be unchecked.
It seems it is not possible to disable Link array afterwards? If that is the case than it is one more reason to have it unchecked by default, as when user finds out that is the issue, he may be far in complex project that removing array and replacing it with another one could be hard or not possible.
I did at first set cylinders slightly bigger. Then I tried to set them exact as base to see if that matters and left it that way.
In mean while, I redo project in 0.18 and there it works as expected (it seems not to have Link array option).
Thanks a lot for help.
App Links are more efficient when you just want to duplicate objects many times; this is a workflow intended for assembly, for example, to duplicate many bolts or screws or nuts.
And you can set the default to create normal arrays. You just need to uncheck the Link array checkbox. Then next time that you open the Draft OrthoArray tool, it will remember the option used last time. This is controlled with the parameter "Draft_array_Link", that you can see in the Parameter editor, under Mod/Draft.
Behaviour of LinkArray seems to be a bit unpredictable: Yesterday the cut definitely didn't work. That's why I tried the regular array instead. I'm not sure about any error message but I'm quite sure I didn't get one. Today I wanted to check for the message - and the cut succeeds! Without any message.
PR submitted here.
The problem is not really about cutting using Link, but unsafe pointer casting in cut view provider. Because ViewProviderLink overrides Part.Feature (type of draft link array)'s original view provider, cut view provider must not assume its child object's view provider type.
Regarding the use of link array for boolean operation, there is indeed a disadvantage with current upstream. The color in the array will NOT be passed to boolean feature. This problem will be solved once my topo naming feature is merged.
Thanks for the quick fix.
