3D surface path hangs up on solid surface
Routerworks
Post by Routerworks »
OS: Windows 10 (10.0)
Version: 0.19.22366 (Git)
Hash: 34c11fcc63efa2fc72cbc74c75c76e9f19d5c84c
Python version: 3.8.5
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
also: Python 3.8.5 | packaged by conda-forge | (default, Aug 29 2020, 00:43:28) [MSC v.1916 64 bit (AMD64)] on win32
It seems to work ok with 3D models made in Freecad however, when I bring in a solid made from a mesh I get as far as choosing "3D surface" and it hangs up. My goal is to be able to machine 3D curvilinear objects (example: chess piece). Machine it from 4 faces.
Thanks in advance.
Routerworks
Re: 3D surface path hangs up on solid surface
Is there any way of getting Python OCL to work on solid made from an obj. file or mesh converted to a solid. Or, is this question in the wrong space?
Thanks.
Routerworks wrote: Wed Sep 16, 2020 10:15 pm Is there any way of getting Python OCL to work on solid made from an obj.
OCL is used for 3D surface.
Routerworks
Ok, so one plane of a 3D object (such as a chess figure, knight) would not be considered a 3D surface? It's only something made up of circles, holes and squares etc.?
Thanks for responding.
Routerworks
This post shows some of the possibilities of 3D surface: https://forum.freecadweb.org/viewtopic.php?t=41997.
Is there a certain reason why you want to use OCL? Wouldn't any other tool be just as good af it creates suitable GCodes?
Routerworks
Yes, I'm looking for anything I can machine a contoured surface with.
Thanks
So I would recommend to start with a simple cube from Part workbench.
Create a Job and a Contour (0.18) or a Profile operation.
Next create an object with a pocket-not-through-all and create a Pocket operation. Make sure that the tool you choose is smaller than the pocket.
This should get you going with Path workbench and you don't need OCL for this.
herbk
Post by herbk »
Hi
Routerworks wrote: Wed Sep 16, 2020 10:15 pm Is there any way of getting Python OCL to work on solid made from an obj. file or mesh converted to a solid. Or, is this question in the wrong space?
Thanks.
do you have an example fille for us ?
Gruß Herbert
Routerworks
Thank you for your responses. I have created many 3D pieces in Freecad and successfully generated "Path" g codes. The problem for me is trying to import the surface of an STL or obj. mesh file that I have converted to a solid. I tried to upload the sample chess piece (knight, looks like a horse's head) but the file was too large. The piece is only about 3 inches tall but there are probably a lot of facets from converting the mesh. The problem is the same for machining any natural 3D object such as an apple or small figure. Generally if I can machine it from 4 planes 90 Degrees to each other, I can create the complete object. Hope this helps.
Thank you.
