glider workbench
Gift
Re: glider workbench
Postby Gift » Fri Sep 18, 2020 8:32 pm
thomas-neemann wrote:
Fri Sep 18, 2020 6:09 pm
looo wrote:
Fri Sep 18, 2020 1:21 pm
ich konnte die datei in 2,5 minuten laden, wenn ich freecad unter linux mit höchster priorität laufen lasse. (auf einem 7 jahre alten büro-pc)
wenn ich daraus mit part einen verbund mache und als fcstd abspeichere, läd die datei nach freecad-neustart in 8 sekunden. das halte ich für brauchbar.
lg thomas
Das brauch ich nicht in Sekunden. 8-)
looo
Postby looo » Mon Sep 21, 2020 8:24 am
Gift wrote:
Fri Sep 18, 2020 8:23 pm
I think it is very fast.
cute, thanks a lot :D
bujak
Postby bujak » Wed Dec 16, 2020 11:31 pm
Ok I don't understand one thing, I don't know if it's a bug or if I just don't get it, but the exported svg looks like it has no panel or ribs, there's almost nothing there. To reproduce:
1. Create new glider
2. Export with "unwrap glider" tool
there are some schematics in the svg but not what I would expect. It's on FreeCad v0.19
looo
Postby looo » Thu Dec 17, 2020 11:57 am
Best to usw dxf-format. Thus should contain all the Panels.
bujak
Postby bujak » Thu Dec 17, 2020 4:04 pm
thanks, bTW I figured it out, it was no stroke color and 1px thin lines, i had to change the color and increase the line width
bujak
Postby bujak » Mon Dec 21, 2020 10:27 pm
OK another thing, when I put a diagonal rib and a single skin rib at the same time, it never outputs any plans. So I guess they don't work together. Or is it a bug?
zenti bishop
Postby zenti bishop » Wed Feb 03, 2021 9:11 am
Good day Looo
I Love your program i have designed a mini wing that i now want to manufacture .
I am having difficulties' exporting glider to dxf as it only gives me 'jason and openoffice format .
Not sure what to to please advise .
Kind regards
Zenti
bujak
Postby bujak » Thu Feb 11, 2021 9:00 am
I'm baffled by one thing (I'm on the stable branch): when I make the lowest gallery lines a bit longer (the ones that connect to the riser), the top of the gallery gets some "punk" artifacts. Looks like the top gallery lines are "reversed". Is it a bug or some underlying design limitation? I'm not sure what I'm looking at. Am I misunderstanding something about how to change the lines lenght?
Screenshot 2021-02-11 at 09.20.20.png (131.77 KiB) Viewed 344 times
Screenshot 2021-02-11 at 09.19.34.png (54.62 KiB) Viewed 344 times
looo
Postby looo » Thu Feb 11, 2021 11:10 am
you need to reset the location of the bottom-attachment point. Otherwise the total length of the given lines is too long. see this image:
Bildschirmfoto von 2021-02-11 12-06-30.png (169.6 KiB) Viewed 312 times
bujak
Postby bujak » Thu Feb 11, 2021 1:13 pm
thanks! it worked
