In this Post I was suggesting to extend the "Map Parameter" attachment (that only allows single curves right now) to also allow Wires (I have shown an animation in that post to show why).
I now implemented this and did some testing. It works.
Kind of.
If just BRepAdaptor_CompCurve::D1() would return parameter values that are evenly distributed along the wire. Which it doesn't:
Anybody knows if this is a feature or am I doing something wrong. Or should I consider this a bug?
BRepAdaptor_CompCurve::D1() parameter distribution??
Cheers,
Markus
Markus
Re: BRepAdaptor_CompCurve::D1() parameter distribution??
IMHO you must not assume any specific parametrisation.
This is not a bug. It is up to you to compute the right sequence of parameters to get your "constant speed" samples.
EDIT : GCPnts_UniformAbscissa may be useful
- tanderson69
It might. There are several constructors for BRepAdaptor_CompCurve. I searched freecads code base and the only BRepAdaptor_CompCurve constructor I found, was the constructor using the single parameter wire. So I can only guess that using another constructor and passing true for 'KnotByCurvilinearAbcissa' parameter would give you what you want. You can also specify the parametric range.
Good guess, hit the spot, many thanks!tanderson69 wrote: ↑Wed Sep 30, 2020 1:37 pm... So I can only guess that using another constructor and passing true for 'KnotByCurvilinearAbcissa' parameter would give you what you want...
Cheers,
Markus
Markus
Thanks to tanderson69, the roller chain can now be properly animated using plain Assembly 4 functionality and a little expression trickery (that probably needs revisiting to improve performance), no extra code needed.
Could anybody offhand give some guidance on the FreeCAD pull/enhancement request process, please?
I don't want to collide with anything with my very first contribution...
Cheers,
Markus
Markus
Checkout our wiki page called Source code management
