I just tried this out, and this seems to work fine in my fairly simple scenarios, so far.Zolko wrote: ↑Thu Oct 15, 2020 12:00 pm I don't know whether Asm3 links are different from standard App::Links, but for standard App::Links you can edit a broken link from the GUI:
Select the broken link in the Model tree, then in its PropertyView select the small button for LinkedObject, and in the pop-up list select the new target object. Note that only already opened document will be show here, so you need to have the target document already opened. Note also that this supposes that all referenced datums in the old target object are present in the new target object. Else, you're on your own.
Thank you... that's fairly straightforward to just re-point the link.
You guys are super responsive. I appreciate that! In a great many ways, I feel like this move away from Fusion 360 to FreeCAD is a big upgrade.
