Air Plane Design Workbench - discussion thread
a179308
Postby a179308 » Sun Jan 05, 2020 6:06 pm
Hello,
I've have started a Air Plane Design Workbench :https://github.com/FredsFactory/FreeCAD_AirPlaneDesign . Available to install in the addon manager, Air Plane Design Workbench V0.1 and V0.2 can create a wings based on panel and profil.
Please don't use the V0.1 it was a first draft, based on sheet with which I designed the wing of my ASK13 (https://fredsfactory.fr).
The approach on the V0.2 is completely different and integrate parametric objects based on a dedicated UI.
You can use this discussion thread to interact with me.
Hoping this can be of some utility for FC users.
I created this topic to avoid technical discussions in the topic Announcements & Features.
Fred
a179308
Re: Air Plane Design Workbench - discussion thread
Postby a179308 » Sun Jan 05, 2020 6:12 pm
Generic approach to create a wing :
The process is very simple :
0 -Workbench : Image, import 3views and scale it to the right dimension
1 - Workbench : Air plane design, create a rib
Capture d’écran 2020-01-02 à 13.30.14.png (372.15 KiB) Viewed 1175 times
2 - Create two sketch
Capture d’écran 2020-01-02 à 13.31.50.png (203.84 KiB) Viewed 1175 times
he result :
Capture d’écran 2020-01-02 à 13.33.58.png (70.23 KiB) Viewed 1175 times
3 - Workbench : Curved Shapes, "Create an Array" after select the rib and sketches. You can adjust the number of items, if you want a solid or a surface or only ribs.
Capture d’écran 2020-01-02 à 13.34.22.png (124.43 KiB) Viewed 1175 times
don't forget to recompute if you change your rib profile
Next step for me is to develop a wizard in the Air Plane Design Workbench to integrate this approach...
The file :
Sirius_2009-Wing.FCStd
(362.66 KiB) Downloaded 41 times
Fred
hammax
Postby hammax » Sun Jan 05, 2020 7:05 pm
Warning:
Don't store your own Data, Examples and Pictures under the folder "AirPlaneDesign"
they get lost when updating AirPlaneDesignWB.
a179308
Postby a179308 » Sun Jan 05, 2020 7:38 pm
To answer to Will_C https://forum.freecadweb.org/viewtopic. ... 37#p358037 :
"I would have two questions regarding your WB.
1) What is the intent of the property "Rib Profil" which i circled in the attached Picture?
I can change the profile by typing in a new number in the section "Naca Profil".
Is Rib Profil only necessary if I want to use a DAT file?
question ribprofile.JPG (27.29 KiB) Viewed 1152 times
the "Rib profile" field is either the name of the DAT file if the "Naca Profile" field is empty; if the Naca Profile field is filled, the value in the "Rib profile" field is not taken into account.
2) Is it possible to select and/or attach the rib geometry to a vertex?
When I create a rib it just appears at a random point and I didn't find a way to set the origin during creation.
It would be helpful if I could fix the leading edge of the rib to a parametric vertex.
At this point it is not possible, but can you share a file with an example so that I understand what you want to do?
Fred
Will_C
Postby Will_C » Mon Jan 06, 2020 3:50 pm
Fred
I'm currently working on a construction of a model plane based on a pdf-sketch.
Since I'm not used to FreeCAD yet, I am trying different approaches to design the model.
My current approach is to create a system of wires with parametric edges and vertices which define the significant shape of the model as shown below. The resulting vertices clearly define later positions for ribs, frames and other supports.
Model Wires.JPG (65.27 KiB) Viewed 1106 times
Based on that I want to allign the objects (e.g. ribs) which will create the faces/outer hull of the model. I wanted to use tools from the CurvesWB
to get the surfaces and therefore wanted to allign the NACA profiles from your WB to my vertices.
I "parametrized" the position of the NACA profiles by linking the Placement to the position of the respective vertice of my wire drawing.
Not ideal since I have to be super carefull not to run into topological problems but it is ok for the moment.
I'll probably have to redo the model a few times anyway until I find the right approach.
Here's am example of the Elevator:
The blue circle above shows the vertex I'm adressing in the placement of the NACA profile below.
I did the same with the chord length by using the distance of two vertices from my sketch.
This doesn't allow me to get an angle, but it should give me the precision needed for creating faces or solids from the sketches.
And thank you for the wing example. I will take a look into it. I'm sure this will simplify my workflow.
BR,
Will
hammax
Postby hammax » Wed Jan 15, 2020 6:48 am
… a little "plane-impression" resulting from answering Will's CurvesWB questions concerning fuselage.
https://forum.freecadweb.org/viewtopic. ... 30#p359167
Only by eye, done without AirPlaneDesignWB, but maybe a food for it.
GordLoft_4.FCStd
(129.61 KiB) Downloaded 33 times
Zolko
Postby Zolko » Tue Feb 04, 2020 1:35 pm
Hi, would this WB help in designing a rib construction wing ? Specifically, would it allow to make a geodesique (or geodetic ?) wing structure ?
Image Image
unclesal
Installation problem
Postby unclesal » Tue Oct 27, 2020 3:23 pm
Hello and thank you very much for your work.
I'm interested in looking at your module.
I have installed it using the plugin manager. When I turn on the workbench,
I see next message. Gentoo Linux, Qt=5.15.1. Tell me please, what is wrong?
20:09:01  No module named 'PySide2.QtUiTools'
20:09:01  Traceback (most recent call last):
  File "<string>", line 58, in Initialize
  File "/home/sal/.FreeCAD/Mod/AirPlaneDesign/airPlanePanel.py", line 31, in <module>
    from airPlaneRib import WingRib, ViewProviderWingRib
  File "/home/sal/.FreeCAD/Mod/AirPlaneDesign/airPlaneRib.py", line 32, in <module>
    from airPlaneDesignProfilUI import SelectObjectUI
  File "/home/sal/.FreeCAD/Mod/AirPlaneDesign/airPlaneDesignProfilUI.py", line 22, in <module>
    from PySide import QtCore, QtGui, QtUiTools
  File "/usr/lib64/freecad/Ext/PySide/QtUiTools.py", line 1, in <module>
    from PySide2.QtUiTools import *
a179308
Postby a179308 » Tue Oct 27, 2020 8:29 pm
Hello
Which version of FreeCad do you have installed ?
Fred
unclesal
Postby unclesal » Wed Oct 28, 2020 5:08 am
OS: Gentoo/Linux (KDE//usr/share/xsessions/plasma)
Version: 0.19.22834 (Git)
Branch: (HEAD detached at refs/git-r3/HEAD)
Hash: 34154019168b2f6fc9e2dc673f80ca936cfb61b6
Python version: 3.7.9
Qt version: 5.15.1
Coin version: 4.0.0
OCC version: 7.4.0
Locale: Russian/Russia (ru_RU)
