Curved Shapes Workbench
Vincent B
Re: Curved Shapes Workbench
Post by Vincent B »
The vertexes are not aligned, you should redraw the sketches or use joincurve. Joincurve have a offset option now is need.
Corner break parameter can be used as well.
CurvedSegment.FCStd
(19.96 KiB) Downloaded 60 times
christi
Post by christi »
Hi Zolko and GlouGlou,
As you found out, the Twist parameter did not work with sketches that have more than one line segment.
Creating a join curve solves this by 1. creating a single curve and 2. moving the starting point to the top.
For those who do not know this trick and to get rid of the problem with the twist parameter, I have implemented Zolkos approach to reorder the line segments. The twist parameters will now reorder the line segments instead of the pole points of the lines. If you have 6 line segments, you can apply twists with a multiple of 60 degrees. I think this will work for most designs.
Check out the new version of the CurvedShapes Workbench.
Vincent B
Post by Vincent B »
InterpolatedMiddle doesn't work with this file. Or I missed something?
interpolated.FCStd
(15.21 KiB) Downloaded 60 times
christi
Post by christi »
GlouGlou wrote: Sun Nov 15, 2020 8:51 am Hi,
Ups, there was a bug, sorry. I fixed it.
krazywulf1983
cuvres WB shrunk my work?
Post by krazywulf1983 »
so it look sliek it shurnk one side and grew the otherside in length how do i fix this?
Handle.FCStd
(157.91 KiB) Downloaded 54 times
Reason: Mod note: thread merged in to the main Curves Workbench thread
Re: Curves workbench
Post by Kunda1 »
krazywulf1983 wrote: Fri Nov 20, 2020 2:08 am so it look sliek it shurnk one side and grew the otherside in length how do i fix this?
Mod note:
@krazywulf1983 your thread was merged in to the main Curves Curved Shapes WB thread. Please always paste your full About info in to posts you're asking assistance with. Please edit the above post to do just that. Thank you
Reason: Curved Shapes not Curves workbench
Chris_G
Post by Chris_G »
Kunda1 wrote: Fri Nov 20, 2020 5:25 am
Mod note:
@krazywulf1983 your thread was merged in to the main Curves WB thread. Please always paste your full About info in to posts you're asking assistance with. Please edit the above post to do just that. Thank you
This user uses Curved Shapes WB, not Curves.
Post by Kunda1 »
:facepalm:
Ok, fixed. Apologies.
christi
Re: cuvres WB shrunk my work?
Post by christi »
Select the Sketch BottomFront and select BoundingBox in the View menu. Your base item BottomFront is bigger than the sides Sketch004 in y direction. This is why it is shrunk. To fix this, make a copy of Sketch004 and move the bars so they will cross the boundung box of BottomFront.
drmacro
Post by drmacro »
How does one get the "Items" (shown in orange) to follow the hull curve rather than be parallel to the "Base"?
And what controls the last couple items? Is it possible to have them scale (not sure scale is the right word...) so they fit between the hull curves?
Snip macro screenshot-3d80db.png (106.57 KiB) Viewed 2407 times
OS: Ubuntu 20.04.1 LTS (XFCE/ubuntustudio)
Version: 0.19.
Branch: unknown
Hash: b082c813f820ebdb837ba6ace4b9124f9a73cc4a
Python version: 3.8.5
Qt version: 5.12.8
Coin version: 4.0.0
