Posts: 13434 Joined: Thu Jan 05, 2017 9:03 pm
Post
by Kunda1 » Sun Mar 28, 2021 11:36 am
Dimaxum wrote: ↑ Sun Mar 28, 2021 11:19 am
Still the same issues as before ... starting a drawing in PART, the drawing is made, ut then again I can't work on it.
Have to quite FC and relaunch it agin to continuing my drawing ...
Can you start FreeCAD from a terminal window and see what output you get when it crashes/restarts?
BTW, do you see this phenomena with any other software on your computer?
Posts: 54197 Joined: Tue Mar 17, 2015 9:14 am
Post
by chrisb » Sun Mar 28, 2021 12:20 pm
Did you ever try the older 0.18?
Dimaxum
Posts: 22 Joined: Sat Mar 27, 2021 10:38 am
Post
by Dimaxum » Sun Mar 28, 2021 2:41 pm
Hi there,
No I don't have any other issues on my Mac.
I work with Adobe Illustrator CC without any problems.
Microsoft for Mac is also running just fine.
Yes, I did't have FC 0.18 before and hat the same issues as now in FC 0.19.
Art connects and inspires people
Dimaxum
Post
by Dimaxum » Sun Mar 28, 2021 2:43 pm
Kunda1 wrote: ↑ Sun Mar 28, 2021 11:36 am
How do i star FC from the terminal?
Post
by chrisb » Sun Mar 28, 2021 3:09 pm
- type "terminal" in the spotlight search (which is invoked with CMD+space) and start it.
- type <path_where_FreeCAD_is installed>/FreeCAD.app/Contents/MacOS/FreeCAD --write-log and hit enter.
Dimaxum
Post
by Dimaxum » Sun Mar 28, 2021 3:33 pm
I did copy the line into Terminal ...
This is what I got after I hit enter.
"No such file or directory"
This is line I past into Terminal ...
Also, I did try a view combinations of the path for Terminal, no results.
Dimaxum
Post
by chrisb » Sun Mar 28, 2021 3:58 pm
Dimaxum wrote: ↑ Sun Mar 28, 2021 3:33 pm
You have to change the text "<path_where_FreeCAD_is installed>" to meet your place of installation, it is probably
/Applications/FreeCAD.app/Contents/MacOS/FreeCAD --write-log
Dimaxum
Post
by Dimaxum » Sun Mar 28, 2021 4:05 pm
This is what Terminal says ...
As I can see is that there are a view ERRORS I the report?
What they mean I don't know.
Dimaxum
Last login: Sun Mar 28 17:23:18 on ttys000
iMac:~ gebruiker$ /Applications/FreeCAD.app/Contents/MacOS/FreeCAD --write-log
# packages in environment at /Users/runner/work/FreeCAD-AppImage/FreeCAD-AppImage/conda/osx/APP/FreeCAD.app/Contents/Resources:
# Name Version Build Channel
appdirs 1.4.4 pyh9f0ad1d_0 conda-forge
arpack 3.7.0 hff0ca13_2 conda-forge
blas 2.17 openblas conda-forge
blinker 1.4 py_1 conda-forge
boost 1.72.0 py38h89463c3_1 conda-forge
boost-cpp 1.72.0 hd067f63_4 conda-forge
brotlipy 0.7.0 py38h5406a74_1001 conda-forge
bzip2 1.0.8 hc929b4f_4 conda-forge
c-ares 1.17.1 h0d85af4_1 conda-forge
ca-certificates 2020.12.5 h033912b_0 conda-forge
cairo 1.16.0 h4ec454a_1007 conda-forge
calculix 2.17 hd362bd0_2 conda-forge
certifi 2020.12.5 py38h50d1736_1 conda-forge
cffi 1.14.5 py38ha97d567_0 conda-forge
chardet 4.0.0 py38h50d1736_1 conda-forge
coin3d 4.0.0 h6a6324e_1010 conda-forge
cryptography 3.4.6 py38h1fa4640_0 conda-forge
curl 7.75.0 h06286d4_0 conda-forge
cycler 0.10.0 py_2 conda-forge
decorator 4.4.2 py_0 conda-forge
docutils 0.16 py38h50d1736_3 conda-forge
expat 2.2.10 h1c7c35f_0 conda-forge
ezdxf 0.15.2 py38h94cab2e_0 conda-forge
ffmpeg 4.3.1 hb787a4c_2 conda-forge
flann 1.9.1 hed988e5_1008 conda-forge
fontconfig 2.13.1 hd23ceaa_1004 conda-forge
freecad 0.19.1 py38h3eadfbe_0 conda-forge
freecad.asm3 0.10.2 pyhf0f75e1_16 freecad/label/dev
freeimage 3.18.0 h446b61c_7 conda-forge
freetype 2.10.4 h4cff582_1 conda-forge
future 0.18.2 py38h50d1736_3 conda-forge
gettext 0.19.8.1 h7937167_1005 conda-forge
gitdb 4.0.5 pyhd8ed1ab_1 conda-forge
gitpython 3.1.14 pyhd8ed1ab_0 conda-forge
gmp 6.2.1 h2e338ed_0 conda-forge
gmpy2 2.1.0b1 py38haf64e2c_1 conda-forge
gnutls 3.6.13 h756fd2b_1 conda-forge
graphite2 1.3.13 h2e338ed_1001 conda-forge
harfbuzz 2.8.0 h159f659_0 conda-forge
hdf4 4.2.13 h71d84a9_1004 conda-forge
hdf5 1.10.6 nompi_h34ad4e8_1111 conda-forge
icu 68.1 h74dc148_0 conda-forge
idna 2.10 pyh9f0ad1d_0 conda-forge
ifcopenshell v0.6.0 py38he2be11e_3 conda-forge
ilmbase 2.5.5 hfab91a5_0 conda-forge
jasper 1.900.1 h636a363_1006 conda-forge
jinja2 2.11.3 pyh44b312d_0 conda-forge
jpeg 9d hbcb3906_0 conda-forge
jsoncpp 1.8.4 ha1b3eb9_1002 conda-forge
jxrlib 1.1 h35c211d_2 conda-forge
kiwisolver 1.3.1 py38hd9c93a9_1 conda-forge
krb5 1.17.2 h60d9502_0 conda-forge
lame 3.100 h35c211d_1001 conda-forge
lcms2 2.12 h577c468_0 conda-forge
libblas 3.8.0 17_openblas conda-forge
libcblas 3.8.0 17_openblas conda-forge
libclang 11.1.0 default_he082bbe_0 conda-forge
libcurl 7.75.0 h8ef9fac_0 conda-forge
libcxx 11.1.0 habf9029_0 conda-forge
libedit 3.1.20191231 h0678c8f_2 conda-forge
libev 4.33 haf1e3a3_1 conda-forge
libffi 3.3 h046ec9c_2 conda-forge
libgfortran 4.0.0 7_5_0_h1a10cd1_20 conda-forge
libgfortran4 7.5.0 h1a10cd1_20 conda-forge
libglib 2.68.0 hd556434_1 conda-forge
libiconv 1.16 haf1e3a3_0 conda-forge
liblapack 3.8.0 17_openblas conda-forge
liblapacke 3.8.0 17_openblas conda-forge
libllvm11 11.1.0 hd011deb_0 conda-forge
libnetcdf 4.7.4 nompi_h9d8a93f_107 conda-forge
libnghttp2 1.43.0 h07e645a_0 conda-forge
libopenblas 0.3.10 openmp_h63d9170_5 conda-forge
libopencv 4.5.1 py38h3a1a88b_0 conda-forge
libpng 1.6.37 h7cec526_2 conda-forge
libpq 13.1 h052a64a_2 conda-forge
libraw 0.20.2 hefd3b78_1 conda-forge
libredwg 0.11.3876 py38h9cb336a_0 conda-forge
libssh2 1.9.0 h52ee1ee_6 conda-forge
libtiff 4.2.0 h355d032_0 conda-forge
libwebp-base 1.2.0 h0d85af4_2 conda-forge
libxml2 2.9.10 h802ca4f_3 conda-forge
libxslt 1.1.33 h5739fc3_2 conda-forge
llvm-openmp 11.1.0 hda6cdc1_0 conda-forge
lxml 4.6.2 py38h7d97eb6_1 conda-forge
lz4-c 1.9.2 hb1e8313_3 conda-forge
markupsafe 1.1.1 py38h5406a74_3 conda-forge
matplotlib-base 3.3.4 py38hb24f337_0 conda-forge
meshpy 2020.1 py38he9f00de_0 conda-forge
mpc 1.1.0 ha57cd0f_1009 conda-forge
mpfr 4.0.2 h72d8aaf_1 conda-forge
mpmath 1.2.1 pyhd8ed1ab_0 conda-forge
mysql-common 8.0.23 h694c41f_1 conda-forge
mysql-libs 8.0.23 hbeb7981_1 conda-forge
ncurses 6.2 h2e338ed_4 conda-forge
netgen 6.2.1808 py38h65d59e6_1007 conda-forge
nettle 3.6 hedd7734_0 conda-forge
nine 1.1.0 py_0 conda-forge
nspr 4.30 hcd9eead_0 conda-forge
nss 3.47 hc0980d9_0 conda-forge
numpy 1.20.1 py38h64deac9_0 conda-forge
occt 7.4.0 ha4584bc_7 conda-forge
olefile 0.46 pyh9f0ad1d_1 conda-forge
opencamlib 2019.07 py38hb02f84c_3 conda-forge
opencv 4.5.1 py38h50d1736_0 conda-forge
openexr 2.5.5 h7fa7ffa_0 conda-forge
openglider 0.06 pyh9f0ad1d_0 conda-forge
openh264 2.1.1 hfd3ada9_0 conda-forge
openjpeg 2.4.0 h6cbf5cd_0 conda-forge
openssl 1.1.1j hbcf498f_0 conda-forge
pandas 1.2.3 py38h1588c1c_0 conda-forge
parabem 0.3.0 py38hd9c93a9_0 conda-forge
pcl 1.11.1 h7984e4d_1 conda-forge
pcre 8.44 hb1e8313_0 conda-forge
pillow 8.1.2 py38h83525de_0 conda-forge
pip 21.0.1 pyhd8ed1ab_0 conda-forge
pivy 0.6.6 py38h07f26b5_0 conda-forge
pixman 0.40.0 hbcb3906_0 conda-forge
ply 3.11 py_1 conda-forge
py-opencv 4.5.1 py38h9bb44b7_0 conda-forge
pycollada 0.7.1 py_0 conda-forge
pycparser 2.20 pyh9f0ad1d_2 conda-forge
pyexcel-ezodf 0.3.4 py_0 conda-forge
pyopenssl 20.0.1 pyhd8ed1ab_0 conda-forge
pyparsing 2.4.7 pyh9f0ad1d_0 conda-forge
pyside2 5.13.2 py38hc6340e1_4 conda-forge
pysocks 1.7.1 py38h50d1736_3 conda-forge
python 3.8.8 h4e93d89_0_cpython conda-forge
python-dateutil 2.8.1 py_0 conda-forge
python_abi 3.8 1_cp38 conda-forge
pythonocc-core 7.4.1 py38hd3de0cb_0 conda-forge
pytools 2021.2 pyhd8ed1ab_0 conda-forge
pytz 2021.1 pyhd8ed1ab_0 conda-forge
pyyaml 5.4.1 py38h5406a74_0 conda-forge
qhull 2020.2 h940c156_0 conda-forge
qt 5.12.9 h126340a_4 conda-forge
qt.py 1.2.2 py_0 conda-forge
readline 8.0 h0678c8f_2 conda-forge
requests 2.25.1 pyhd3deb0d_0 conda-forge
scipy 1.4.1 py38h38b60c6_3 conda-forge
setuptools 49.6.0 py38h50d1736_3 conda-forge
six 1.15.0 pyh9f0ad1d_0 conda-forge
smesh 8.3.0.3 py38h7dac498_10 conda-forge
smmap 3.0.5 pyh44b312d_0 conda-forge
solvespace 2.4.1 py38h281f984_0 freecad/label/dev
soqt 1.6.0 h02c1c16_0 conda-forge
sqlite 3.34.0 h17101e1_0 conda-forge
svgwrite 1.4.1 pyhd8ed1ab_0 conda-forge
sympy 1.7.1 py38h50d1736_1 conda-forge
tbb 2020.2 h940c156_4 conda-forge
tk 8.6.10 h0419947_1 conda-forge
tornado 6.1 py38h5406a74_1 conda-forge
urllib3 1.26.4 pyhd8ed1ab_0 conda-forge
vtk 8.2.0 py38h3f69d5f_218 conda-forge
wheel 0.36.2 pyhd3deb0d_0 conda-forge
x264 1!161.3030 h35c211d_0 conda-forge
xerces-c 3.2.3 hd3a8c1e_2 conda-forge
xlrd 2.0.1 pyhd8ed1ab_3 conda-forge
xlutils 2.0.0 pyh9f0ad1d_0 conda-forge
xlwt 1.3.0 py_1 conda-forge
xz 5.2.5 haf1e3a3_1 conda-forge
yaml 0.2.5 haf1e3a3_0 conda-forge
zlib 1.2.11 h7795811_1010 conda-forge
zstd 1.4.8 h62961b2_0 conda-forge
FreeCAD 0.19, Libs: 0.19R24276 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
GVA error: Not detecting IGPU in IORegistry!
GVA error: Not detecting valid offline codec!
GVA info: Successfully connected to the Intel plugin, offline Gen6
[1044:70147:0328/180326.632482:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.632547:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.634404:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.634458:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.635981:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.636018:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.636901:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.636926:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.637520:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.637543:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.638114:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.638136:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.638713:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.638736:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.639311:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.639338:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.640308:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.640361:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
[1044:70147:0328/180326.641631:ERROR:gl_context_cgl.cc(136)] Error creating context.
[1044:70147:0328/180326.641684:ERROR:gles2_command_buffer_stub.cc(262)] ContextResult::kFatalFailure: Failed to create shared context for virtualization.
Post
by chrisb » Sun Mar 28, 2021 4:38 pm
Dimaxum wrote: ↑ Sun Mar 28, 2021 4:05 pm
Please edit your post and put the log output between code tags using the button </>.
Dimaxum
Post
by Dimaxum » Mon Mar 29, 2021 5:05 am
Sorry chrisb,
I don't understand it what you say ... can you explain it clearer.
Thank you
Dimaxum
