No, it does not appear in the last file uploaded by Bance, even after I put in the lips:
- TempSnip3.PNG (43.07 KiB) Viewed 61 times
This was only a Practice Bowl, to find the best way to put and trim the Pipe in the Real Bowl, which has a more complex topiology than the Practice Bowl. My patent attorney would prob'ly scowl very deeply if I revealed its secrets to anyone, at this point, not properly sworn to silence ( I may have said too much already; now you already know it's a GroovyBowl with a Polar Array called 'Slotties'), but I can try to reproduce the phenomenon with similarly complex curvatures unlike those of the Real Bowl.
I have re-read the Sketcher Lecture several times, each time I recognize something I didn't used to know, but learned from Trial and Error or Forum Queries, not the Sketcher Lecture, because partly I can't seem to find the 'Zoom' button on it, and my magnifier app ain't so hot either:
- TempSnip.PNG (35.96 KiB) Viewed 61 times
so some readings I just missed stuff, or got lost in the jargon, or otherwise confused, or simply skimming anything not related to the Real Bowl, except now I know it's All Related.
Started out thinking a 'ShapeBinder' was some kind of Master Constraint, to hold selected elements in position relative to one another during move operations, when I thought 'copy and place' was still in vogue. Still don't know Linked from UnLinked; might as well say Flapped or Flipped, for all these descriptions tell
me.
Another time I thought '3-D View' meant the Navigation Cube, so Imagine trying to follow a Tutorial saying 'Click anywhere in the 3-D View' and clicking the Navigation Cube instead; my Models kept going Kerblooey, it seemed, but it was just Operator Idiocy after all.
Here's a picture from the Lecture, as it appears on my screen:
- TempSnip1.PNG (28.97 KiB) Viewed 61 times
Note the zigs in the vertical edges. These actually ripple as I scroll the image up and down the screen, so I don't know whether I've got a real problem with the Real Bowl, or if it's just a manifestation of cheap hardware (though the Ziggy edge of the Real Bowl does not ripple like the images from the Lecture). If you say so strong enough, I may be able to swing a new computer out of this.
Another thing noticed this last Sketcher Lecture reading - 'Links out of Allowed Scope' messages. I see this from time-to-time, and sometimes after I've re-built something that worked the first time before I tore it down and started over. No clue how to handle it.
Yes, I think a new computer might be in order, what do you say?
- TempSnip4.PNG (15.95 KiB) Viewed 61 times
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
