Curves workbench
bartekdko
Re: Curves workbench
Post by bartekdko »
Ok, but could you adviced how to keep same position in reference to Body origin. Whenever I try draft "throw" my sketch to XY plane.
Kundalini.... :idea:
Vincent B
Post by Vincent B »
Gordon crash. :roll: (wb updated)
both releases:
OS: Windows 10 Version 2004
Version: 0.20.24720 (Git)
Hash: 8b0c58d1b45017ad42bf0fa8f827f1cf22a398e7
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/France (fr_FR)
OS: Windows 10 (10.0)
Version: 0.20.24665 (Git)
Hash: 5d49bf78de785a536f941f1a6d06d432582a95d3
Python version: 3.8.8
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
manifold4.FCStd
(20.69 KiB) Downloaded 48 times
Vagulus
Post by Vagulus »
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
Locale: English/New Zealand (en_NZ)
The Wiki for Curves.wb https://wiki.freecadweb.org/Curves_Workbench does not include this
210426 Cirves - Blend Curve Icon.png (1.81 KiB) Viewed 1805 times
Icon (Blend curve between two edges) And I am having trouble getting it to work. I have two lines, each of which are normal to a sketch - the sketches are on different planes
210425 Sketch Normals.png (4.36 KiB) Viewed 1805 times
I'd like a curve between the two lines as a Track for a Sweep operation.
Would someone be so kind as to itemise the sequence of operations to use this feature.
Thanks
"It is much harder to simplify than to complicate."
Joseph Kimble
Chris_G
Post by Chris_G »
Select 2 edges in the 3D View and activate the tool.
Then you can adjust some properties :
  • Auto-Scale : let the tool automatically adjust the scaling of the curve at both ends
  • Output : only the blend curve, or a wire made of blendcurve + input edges, or the 3 edges joined together into a single curve
Then for each edge :
  • Continuity : the desired level of continuity between input edge and blendcurve (from C0 to G4)
  • Parameter : the distance at which the blendcurve start from input edge end
  • Reverse : change the edge end to which the parameter above is applied
  • Scale : if Auto-Scale is not set, adjust the shape of the curve on this end
Vagulus
Post by Vagulus »
Thank you
Joseph Kimble
Vagulus
Post by Vagulus »
Chris_G wrote: Mon Apr 26, 2021 6:04 am Select 2 edges in the 3D View and activate the tool.
Well, I get a curve
210425 First Curve.png (2.81 KiB) Viewed 1768 times
but it is a bit more elaborate than I expected. There is an error message in the Report View
15:38:58 Part::FeaturePython / Blend_Curve: Links go out of the allowed scope
I expected the Curve to start at the inward end of each line but it seems to start wherever it wants
210426 Start of Curve.png (1.25 KiB) Viewed 1768 times
(The other end is similar.) However, the Curve goes through the Oval Sketch and the Round Sketch so I try a Sweep and I get this error message
210426 Error.png (6.88 KiB) Viewed 1768 times
Chris_G wrote: Mon Apr 26, 2021 6:04 am Then you can adjust some properties :
How do I adjust these properties? I cannot find an Icon or a Properties List. Is there a list of what these Property Adjustments do?
Joseph Kimble
Chris_G
Post by Chris_G »
Vagulus wrote: Mon Apr 26, 2021 8:07 am There is an error message in the Report View
Curves WB tools are not supposed to work on PartDesign objects.
But you can ignore this warning.
Vagulus wrote: Mon Apr 26, 2021 8:07 am I expected the Curve to start at the inward end of each line but it seems to start wherever it wants
It doesn't start where it wants, it starts where you clicked the edge.
You can correct this with Parameter1 and Parameter2 properties as in the screenshot below.
Vagulus wrote: Mon Apr 26, 2021 8:07 am How do I adjust these properties? I cannot find an Icon or a Properties List. Is there a list of what these Property Adjustments do?
Vagulus
Post by Vagulus »
Great! :D With a bit of fiddling I got
210426 Revised Curve.png (2.39 KiB) Viewed 1740 times
which is much more like the curve I wanted. Unfortunately, I still get
and I still get
210426 Error.png (6.88 KiB) Viewed 1740 times
except it's TopoDS::Wire this time. (Something has changed! :D )
I am afraid I don't speak FreeCAD fluently enough to know what TopoDS::Wire means and Uncle Google's no help this time.
Is the inside curve just too tight?
Manifold.FCStd
(20.01 KiB) Downloaded 41 times
Joseph Kimble
Vagulus
Post by Vagulus »
More playing and I got
210426 Is This It.png (23.81 KiB) Viewed 1729 times
Now I'll got and print it. (This'll be fun! :lol: )
Thanks for the help.
Joseph Kimble
Chris_G
Post by Chris_G »
Your AdditivePipe should use the green binder as Sweep Spine.
However, the generated sweep still self intersect.
Manifold_fixed.FCStd
(852.04 KiB) Downloaded 46 times
