[SOLVED] Compilation fails with OCCT 7.5.2.
fcaduser
Post by fcaduser »
Hello FC team.
I'm using the last version, that is 7.5.2 :
https://git.dev.opencascade.org/gitweb/?p=occt.git
(Debian, but clearly that's not the point here.)
mainuser@station1:~/software/freecad_source/build_2021-04-25$ make -j 1
[  0%] Built target MEFISTO2
[  1%] Built target SMDS
[  1%] Built target SMESHDS
[  2%] Built target Driver
[  2%] Built target DriverSTL
[  2%] Built target DriverDAT
[  2%] Built target DriverUNV
[  3%] Built target SMESH
[  5%] Built target StdMeshers
[  6%] Built target lazy_loader
[  6%] Automatic MOC for target FreeCADBase
[  6%] Built target FreeCADBase_autogen
[  8%] Built target FreeCADBase
[  8%] Generating version_check
git
/home/mainuser/software/freecad_source/build_2021-04-25/src/Build/Version.h.out written
[  8%] Generating Version.h
[  8%] Built target fc_version
[  8%] Automatic MOC for target FreeCADApp
[  8%] Built target FreeCADApp_autogen
[ 10%] Built target FreeCADApp
[ 10%] Automatic MOC for target FreeCADMainCmd
[ 10%] Built target FreeCADMainCmd_autogen
[ 10%] Automatic MOC for target FreeCADGui
[ 10%] Built target FreeCADGui_autogen
[ 21%] Built target FreeCADGui
[ 21%] Automatic MOC for target FreeCADMain
[ 21%] Built target FreeCADMain_autogen
[ 21%] Automatic MOC for target FreeCADGuiPy
[ 21%] Built target FreeCADGuiPy_autogen
[ 21%] Automatic MOC for target FreeCADMainPy
[ 21%] Built target FreeCADMainPy_autogen
[ 21%] Automatic MOC for target Points
[ 21%] Built target Points_autogen
[ 22%] Built target Points
[ 22%] Automatic MOC for target PointsGui
[ 22%] Built target PointsGui_autogen
[ 22%] Built target Test
[ 22%] Automatic MOC for target QtUnitGui
[ 22%] Built target QtUnitGui_autogen
[ 22%] Built target ImageScripts
[ 22%] Automatic MOC for target Image
[ 22%] Built target Image_autogen
[ 22%] Automatic MOC for target ImageGui
[ 22%] Built target ImageGui_autogen
[ 23%] Built target ImageGui
[ 23%] Built target MeshScripts
[ 23%] Automatic MOC for target Mesh
[ 23%] Built target Mesh_autogen
[ 26%] Built target Mesh
[ 26%] Automatic MOC for target MeshGui
[ 26%] Built target MeshGui_autogen
[ 27%] Built target MeshGui
[ 28%] Built target PartScripts
[ 28%] Automatic MOC for target Part
[ 28%] Built target Part_autogen
[ 28%] Building CXX object src/Mod/Part/App/CMakeFiles/Part.dir/ShapeUpgrade/UnifySameDomainPyImp.cpp.o
In file included from /home/mainuser/software/freecad_source/build_2021-04-25/src/Mod/Part/App/ShapeUpgrade/UnifySameDomainPy.h:8,
                 from /home/mainuser/software/freecad_source/src/Mod/Part/App/ShapeUpgrade/UnifySameDomainPyImp.cpp:30:
/home/mainuser/software/occt-0dc2c37/include/opencascade/ShapeUpgrade_UnifySameDomain.hxx:72:15: error: field ‘UnionEdges’ has incomplete type ‘TopoDS_Edge’
   TopoDS_Edge UnionEdges;
In file included from /home/mainuser/software/occt-0dc2c37/include/opencascade/BRepTools_History.hxx:20,
                 from /home/mainuser/software/occt-0dc2c37/include/opencascade/ShapeUpgrade_UnifySameDomain.hxx:20,
/home/mainuser/software/occt-0dc2c37/include/opencascade/TopExp.hxx:31:7: note: forward declaration of ‘class TopoDS_Edge’
 class TopoDS_Edge;
make[2]: *** [src/Mod/Part/App/CMakeFiles/Part.dir/build.make:2199: src/Mod/Part/App/CMakeFiles/Part.dir/ShapeUpgrade/UnifySameDomainPyImp.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:2293: src/Mod/Part/App/CMakeFiles/Part.dir/all] Error 2
make: *** [Makefile:130: all] Error 2
Re: Compilation fails with OCCT 7.5.2.
Post by wmayer »
This looks like an error in OCCT source code.
looks like a new member of the class ShapeUpgrade_UnifySameDomain (it was not there in version 7.5.0). However, the file ShapeUpgrade_UnifySameDomain.hxx doesn't include TopoDS_Edge.hxx.
There is only a forward declaration of TopoDS_Edge in TopExp.hxx but due to the new member of type TopoDS_Edge its class declaration must be known to the compiler.
A workaround is to include TopoDS_Edge.hxx before ShapeUpgrade_UnifySameDomain.hxx in client code but since this is an OCCT issue it's better to report the failure upstream.
Post by wmayer »
This change causes the failure: https://git.dev.opencascade.org/gitweb/ ... 121cf07caf
This struct has been added to ShapeUpgrade_UnifySameDomain.hxx
struct SubSequenceOfEdges
  TopTools_SequenceOfShape SeqsEdges;
without including TopoDS_Edge.hxx
I have reported it to OCCT: https://tracker.dev.opencascade.org/view.php?id=32328
fcaduser
Post by fcaduser »
Thank you very much, I will keep an eye on that.
Post by Kunda1 »
Tracking in 'OCC Bugs in the Bugtracker' forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20264
looo
Post by looo »
wmayer wrote: Mon Apr 26, 2021 6:05 am This change causes the failure: https://git.dev.opencascade.org/gitweb/ ... 121cf07caf
Do we have a patch for this issue? I would like to update the conda-forge package:
https://github.com/conda-forge/occt-feedstock/pull/67
Post by wmayer »
No, but a workaround is to include TopoDS_Edge.hxx before ShapeUpgrade_UnifySameDomain.hxx.
looo
Post by looo »
wmayer wrote: Wed May 12, 2021 12:04 pm
thanks. Can you confirm this patch is correct?
https://github.com/conda-forge/occt-fee ... rade.patch
Post by wmayer »
looo wrote: Wed May 12, 2021 1:29 pm
It's correct but you can then remove #include <TopoDS_Shape.hxx> because it's included by TopoDS_Edge.hxx
fcaduser
Re: [SOLVED] Compilation fails with OCCT 7.5.2.
Post by fcaduser »
A workaround is provided.
