Draft Text: Text not aligned with working plane
Roy_043
Postby Roy_043 » Wed May 12, 2021 2:02 pm
The Draft Text command does not fully respect the current working plane.
Test:
  1. Open the attached file.
  2. Align the Draft workingplane (Draft_SelectPlane) with the face of the box marked with the circle.
  3. Start the Draft_Text command.
  4. Enter 0,0,0 in the local coordinate system.
  5. Result: The coordinates in the LCS are used but the text is aligned with the XY plane of the GCS. See 'Test' text in the image.
If you do the same with the Draft_ShapeString command you will see that coordinates can only be entered in the GCS, but the alignment of the XY plane of the LCS is used. See 'Default' text in the image.
Also compare the Draft_Dimension command which does fully respect the working plane.
draft-text-test.FCStd
(20.64 KiB) Downloaded 26 times
thomas-neemann
Re: Draft Text: Text not aligned with working plane
Postby thomas-neemann » Sun Jun 06, 2021 2:59 pm
Roy_043 wrote: Wed May 12, 2021 2:02 pm
i know you're not looking for a workaround, but here's one for anyone interested. 1 min
https://www.youtube.com/watch?v=hdnZMt_sy7A
phpBB [video]
falls ein video-link von mir schwarz und nicht anklickbar sein sollte, hier der kanal: https://www.youtube.com/channel/UCVcztV ... 03GgKekj_g
es ist auch möglich auf antworten zu klicken um den link zu sehen.
