As said it's very inefficient and will take forever for more complex shapes but for simple shapes it's definitely faster than running the operation by hand.
Maybe some of you find that script helpful:
import FreeCAD as App
import Draft
# First convert all wires to faces
objects = App.ActiveDocument.Objects
for object in objects:
print("Name:{}\t Label: {}\t ".format(object.Name,object.Label ) )
print(" => Faces:{}".format(len(object.Shape.Faces)))
faces = len(object.Shape.Faces)
if (faces == 0):
oldname = object.Name
add_list, delete_list = Draft.upgrade(object, delete=True)
add_list[0].Label = oldname
else:
add_list, delete_list = Draft.downgrade(object, delete=True)
add_list1, delete_list1 = Draft.upgrade(add_list[0], delete=True)
add_list1[0].Label = oldname
# Put objects with the same name in a group
basenames = {}
name = object.Label
basenames[name] = [ object ]
if (len(object.Shape.Faces) > 0):
face = object.Shape.Faces[0]
for subobject in objects:
thisname = subobject.Label
if (thisname.startswith(name) and thisname != name):
print ("Candidate for adding: {} to list {}".format(thisname, name))
isinside=True
for vertex in subobject.Shape.Vertexes:
if (face.isInside(vertex.Point, 0.000001, True) == False):
isinside = False
if (isinside):
basenames[name].append( subobject )
print (" ==> Added")
# Test reverse (shorter name contained in longer name)
else:
isinside = True
if (len(subobject.Shape.Faces) > 0):
face = subobject.Shape.Faces[0]
for vertex in object.Shape.Vertexes:
isinside = False
if (isinside):
print (basenames)
# Cut away the smaller parts from the larger ones
for group in basenames:
list= sorted(basenames[group], key=lambda x: x.Shape.Faces[0].Area, reverse=True)
if (len(list) > 1):
Draft.downgrade(list, False)
for o in list:
o.Visibility = False
