Missing 2 ViewFit icons in toolbar
Std_ViewFitsAll and Std_ViewFitsSelection icons are missing. I'm confused because i can find their SVGs in the source.
Has this been reported on the forum?
OS: Ubuntu Core 20 (KDE/plasma)
Version: 0.20.27054 (Git)
Hash: 1f70e352a85aafdaaf0cb80e0d3359ec4a2e2dce
Python version: 3.8.10
Qt version: 5.15.3
Coin version: 4.0.0
OCC version: 7.5.2
Qt version: 5.15.3
Coin version: 4.0.0
OCC version: 7.5.2
- adrianinsaval
Re: Missing 2 ViewFit icons in toolbar
Aren't they getting overridden by your system icon theme? Check if there's an icon with that name in your theme. Check Fine-tuning to see how to set FreeCAD to ignore the system icon theme
Thanks. I assume you're referring to this parameter?adrianinsaval wrote: ↑Wed Jan 12, 2022 1:49 pm Aren't they getting overridden by your system icon theme? Check if there's an icon with that name in your theme. Check Fine-tuning to see how to set FreeCAD to ignore the system icon theme
Bitmaps/Theme/ThemeSearchPaths (boolean): Set to false so FreeCAD uses it's included icons instead of the system icon theme on Linux.
The last comment is very factual, however, the lack of icons occurs in different OS, and it is unlikely that everyone is using the same icon theme.
OS: Debian GNU/Linux bookworm/sid (KDE/plasma)
Version: 0.20.26720 (Git) AppImage
Branch: (HEAD detached at 7bca26e)
Hash: 7bca26e7c14d4d43374ff7e0c8582735b249cbfd
Python version: 3.9.9
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.3
Locale: Polish/Poland (pl_PL)
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.3
Twórca polskiej wersji Wiki dla FreeCAD, współwórca polskiej wersji GUI.
"Cierpliwym być musisz, by wiedzę zgłębiać tajemną, gdyż ciemna strona mocy niszczącą i silną jest".
It also looks like this for me.
- brak polskich liter w menu BIM.png (68.29 KiB) Viewed 3608 times
entering this parameter solved the problem, in my case it was absent
- adrianinsaval
yes
Not at all, you're both using KDE just with different distros, and even the distros are similar since ubuntu is based on debian, the most likely things is that you are using the same icon theme or a derivative of it (there's a ton of breeze variants with different colors in the kde store)
yes this is normal, most of these parameters need to be created by the user if he wants to change the behavior and the program uses the default value if the parameter is absent.entering this parameter solved the problem, in my case it was absent
Yes yes but I have spoken to one friend in the meantime, I expect he has a completely different configuration.
I also took note of KDE.
Edit:
I see that he also pasted his picture, but did not write anything about the distribution he is using.
Edit:
- adrianinsaval
oh I missed mgr_wojtal's post somehow either way it's the same thing, an icon from the system theme is used. It would be nice if FreeCAD prioritized it's own icons over the system's theme or if that parameter did this instead of entirely removing the possibility of using system icons since the file dialog is missing many icons specific to certain folders
Sorry, feeling obtuse here, but can you help me understand what is happening by default?
What needs to change in FC core to make this behavior disappear without fully deferring to the DE the user is using ?
