Crash on angular dimensions tool
ulrich1a
Re: Crash on angular dimensions tool
Post by ulrich1a »
yorik wrote:@ulrich it seems your version of pivy doesn't take utf8 strings, although it claims to be coin4.
Can you try this in the python console?
It gives
>>> from pivy import coin
>>> print coin.COIN_VERSION
4.0.0a
Ulrich
rockn
Post by rockn »
Some informations :
The error of ulrich1a is the same as mine at the begining (see post #8).
Now I have added some .encodeUtf8 in Draft.py.
I have added a lot of print in Draft.py, I can't find where the message is generated.
I have installed freecad of the stable ppa and I've got the same error as post #8 and ulrich1a report.
I've got some strange bug with Dimension.
jo@jo-desktop-trusty:~$ freecad
FreeCAD 0.14, Libs: 0.14R3692 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011
Draft workbench activated
Indiquez le centre :
Indiquez le rayon :
Indiquez le premier point :
Coin info in cc_string_utf8_get_char(): UTF-8 decoding of string "76.48 �m" failed.
To disable UTF-8 support and fall back to preCoin 4.0 behavior, set the
environment variable COIN_DISABLE_UTF8=1 and re-run the application.
freecad: SoAsciiText.cpp:870: void SoAsciiTextP::setUpGlyphs(SoState*, SoAsciiText*): Assertion `length' failed.
Abandon (core dumped)
It was a little dimension strictly < 0.1 mm.
Set the variable environment like it is saying cause a crash too.
Is there a link ? Is it a coin problem ?
Formations - Assistance - Développement : https://freecad-france.com
shoogen
Post by shoogen »
rockn wrote:
latin1 µ (\xb5) differs form utf8 µ (\xc2\xb5) and a singular \xb5 is not valid utf8.
Post by yorik »
Yes the PPA lacks the fix we began to discuss here. I was waiting until we fix everything to commit, but I will already commit what is fixed so far...
Now normally everything should be converted correctly to utf8 and the µ (\xc2\xb5) error above should disappear.
ulrich1a
Post by ulrich1a »
The angular dimension is now working for me. But it seems, it needs a little bit of optimization. :)
Ulrich
OS: Debian GNU/Linux testing (jessie)
Word size: 64-bit
Version: 0.14.3700 (Git)
Hash: db84a39bc05ac3c566482b83848351ec047255e3
Python version: 2.7.7
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.1
Post by yorik »
ok that's another matter... first I'd like to have it working for everybody...
rockn
Post by rockn »
Oh yeah, well done Yorik the angular dimension is working for me too !
I'm still having this with little dimension line.
  File "/home/jo/Logiciels/FreeCAD/free-cad-code/build/Mod/Draft/Draft.py", line 3217, in updateData
    self.string = DraftGui.displayExternal(l,obj.ViewObject.Decimals,'Length',su).encode("utf8")
<type 'exceptions.UnicodeDecodeError'>: 'ascii' codec can't decode byte 0xb5 in position 6: ordinal not in range(128)
Post by yorik »
Ok then I suppose we need to do this:
self.string = DraftGui.displayExternal(l,obj.ViewObject.Decimals,'Length',su).decode("latin1").encode("utf8")
I'm committing that right now ( git commit cbcbba2 ), please test if all works ok now?
rockn
Post by rockn »
Yeah it's ok ! :D
Post by yorik »
Great! Thanks for testing! I'll commit this to the release014 branch too.
