Extrude from curved surface of cylinder
Re: Extrude from curved surface of cylinder
I just had a thought...this is what we do in the code to create a helix....we put a line on a surface and rap that surface around a cylinder or something like that.....
Reported as issue #1699.
hi
slowly but surely mario
Thanks Every body ......
Special thanks to bejant for his help.
mario52 Can you share your design details how you have done it, if you have used python can you please share that.
hi
the macro Macro_FCCircularText
360 degrees
180 degrees or choice
I have not worked for extrude or boolean operation these procedures take an eternity with me !!
it would be nice, integrated of FreeCAD procedure is not complicated, and jim for the icon ?
mario
360 degrees
mario
hi
version with GUI ( the explanation for lather)
the wiki page Macro_FCCircularText
EDIT new version corrected 23/11/2014 (16h17 Paris)
EDIT new version corrected 02/02/2014 (17h30)
suppression 2 str(
EDIT 15/05/2015 20h34 Paris
replace link to github
the macro Macro_FCCircularText.FCMacro
mario
texte = unicode(self.textEdit.toPlainText())
App.Console.PrintMessage(u"texte " + unicode(texte)+"\n")
suppression 2 str(
mario
@mario52 - Very nice! Thanks for the tool and work.
John
John
Thanks Mario, but when I ran the macro I got the following error message:
Exception (Sat Nov 22 16:36:21 2014): type must be str or unicode, not QString
File "/home/myusername/.FreeCAD/Macro_FCCircularText.FCMacro", line 1131, in on_PU_Benchmarks
ff.on_PU_Execute()
File "/home/myusername/.FreeCAD/Macro_FCCircularText.FCMacro", line 1275, in on_PU_Execute
ss=Draft.makeShapeString(String=texte[ii2],FontFile=PolicePath,Size=SizeCaractere,Tracking=0)
File "/usr/lib/freecad/Mod/Draft/Draft.py", line 2311, in makeShapeString
obj.FontFile = FontFile
Base.FreeCADError: FreeCAD exception thrown (type must be str or unicode, not QString)
could you try
String=unicode(texte[ii2])
Running with Line 1275 changed to:
results in this error message:
ss=Draft.makeShapeString(String=unicode(texte[ii2]),FontFile=PolicePath,Size=SizeCaractere,Tracking=0)
Exception (Sat Nov 22 17:14:26 2014): type must be str or unicode, not QString
