Element widget for Sketcher WB
jmaustpc
Re: Element widget for Sketcher WB
Post by jmaustpc »
Hi Abdullah
I was just now testing your elements widget in master
OS: Ubuntu 14.04.1 LTS
Version: 0.15.3976 (Git)
Hash: f647f254903047d7b410e878fbf465f91021b654
Python version: 2.7.6
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.1
I just realised that it does not support external geometry. It does support construction mode elements, but not external geometry linked elements.
I have created a feature request and assigned it to you....I hope that is OK with you...if not I will unassigned it. :)
Jim
jmaustpc
Post by jmaustpc »
@ Abdullah
This is the feature request on the bug tracker
issue #1728
by the way I think congratulations are in order....if I am not mistaken this is your first ticked assigned to you relating to code in master..!!! :)
Jim
abdullah
Post by abdullah »
Thanks!! Well it is ok to assign it to me... I will take a look after the ellipse implementation...
jmaustpc
Post by jmaustpc »
This topic was just about to be bumped off the first page of topics one the developer's forum, it was the last item....not any more! :)
I noticed a while back that external geometry items are not supported in you element selector tool and I kept forgetting to ask...is this intended, or a bug or is this post of mine a feature request? :)
Jim
abdullah
Post by abdullah »
Hi Jim!
I know I have it assigned to me. I was planning to do it after ellipse support, but I will try to do it this week.
It wasn't included in the original package because:
1. I have never used external geometry :oops:
2. I was totally unaware of it.
What you can do to help me is upload that freecad file (or any other using exrernal geo), so that I can test the implementation...
abdullah
Post by abdullah »
Hi Jim!!
I did something (basically add all the external elements to the widget), apparently everything started working "out of the box", which I was not expecting as I am not aware of all the implications of working with external geometry (constraints working?). Therefore I can only tell you: it seems (to me) it works, but someone knowing how to work with external geometry (knowing how to expect from working with it) shall test very well the widget before we can propose this for master.
Specially, anyone using python with FreeCAD, this "Edge-3" is what you would expect as extended name, or more "ExternalEdge3", or does not matter??
Let me know if you find any bug, or anything does not work as expected...
Code:
https://github.com/abdullahtahiriyo/Fre ... master.git
* [new branch] elementwidget_externalgeometry
If you have some idea and want to create "specific icons" (circle, line, arc,...) for the external geometry, I can integrate them. Do not feel compelled to do it, just if you find it useful and want...
jmaustpc
Post by jmaustpc »
I'll try it and think about it.
My first thought is that all external geometry elements should just use the same icons as their equivalent normal entities, as this is what we do with construction geometry.
Here is a multi step model using quite a few construction lines and external geometry (point, line, arc and circle).
fancy_block_external_geometry_examples1.fcstd
(115.01 KiB) Downloaded 58 times
the file was made in FreeCAD from today's master, with both the auto-refine options turned off.
Version: 0.15.4087 (Git)
Hash: f0bf3cb6abba823ef152f616780bde6beb7e2740
Qt version: 4.8.6
OCC version: 6.7.1
Jim
abdullah
Post by abdullah »
jmaustpc wrote:I'll try it and think about it.
Of course, in addition and only if you want and find it useful, construction geometry can also be differentialed. This is your choice.
jmaustpc wrote: Here is a multi step model using quite a few construction lines and external geometry (point, line, arc and circle).
Beautiful!! :shock: I played a little bit with it. I see no strange behaviour... but I am new to external geometry... I wait for your tests...
abdullah
Post by abdullah »
Jim,
when you have this tested, let me know, so that I ask for the pull request...
jmaustpc
Post by jmaustpc »
Hi Abdullah
I Have compiled it, and started testing...I'll come back to it soon.
Jim
