Shut down of LGTM.com
saso
Post by saso »
As it was announced in August, LGTM.com was shut down and as per the recommendation in the announcement we could try to set it up again with GitHub Actions... https://github.blog/2022-08-15-the-next ... -scanning/
Actions for running CodeQL analysis
https://github.com/github/codeql-action
https://github.blog/2023-01-09-default- ... -scanning/
https://github.blog/2023-04-17-multi-re ... ositories/
saso
Re: Shut down of LGTM.com
Post by saso »
Few other security related GitHub Actions that could possibly be interesting to check and maybe added to FC GitHub Actions...
OpenSSF Scorecard - Security health metrics for Open Source
https://securityscorecards.dev/
https://github.com/ossf/scorecard
https://opensource.googleblog.com/2023/ ... later.html
https://openssf.org/blog/2024/04/17/bey ... forcement/
OSV-Scanner (Already integrated in OpenSSF Scorecard)
https://github.com/google/osv-scanner
https://google.github.io/osv-scanner/
https://security.googleblog.com/2022/12 ... ility.html
https://security.googleblog.com/2023/03 ... cycle.html
https://opensource.googleblog.com/2024/ ... ities.html
https://osv.dev/
https://github.com/google/osv.dev
https://github.com/ossf/osv-schema
Supply-chain Levels for Software Artifacts, or SLSA ("salsa")
https://slsa.dev/
https://slsa.dev/blog/2022/08/slsa-gith ... generic-ga
https://openssf.org/press-release/2023/ ... 0-release/
https://security.googleblog.com/2023/04 ... tware.html
https://github.com/slsa-framework/slsa
https://github.com/slsa-framework/slsa-verifier
https://github.com/slsa-framework/slsa-github-generator
Protobom is a protocol buffers representation of SBOM data
https://openssf.org/press-release/2024/ ... e-project/
https://github.com/bom-squad/protobom
https://openssf.org/projects/protobom/
Socket proactively detects and blocks 70+ signals of supply chain risk in open source code, for comprehensive protection
https://socket.dev/
ClusterFuzzLite
https://google.github.io/clusterfuzzlite/
https://google.github.io/clusterfuzzlit ... b-actions/
https://github.com/google/clusterfuzzlite
Also the use of https://app.stepsecurity.io as often recommended by the above OpenSSF Scorecard for the different "Token-Permissions" and "Pinned-Dependencies" issues...
And the Google Engineering Practices Documentation https://google.github.io/eng-practices/ and OpenSSF Guides https://openssf.org/resources/guides/
