You may have had an issue because of the exact name of the directory. In most O/Ses you would expect to have issues if the directory really was named "FreeCAD 0.14" because it has a "full stop" in the name....even the space can cause issues in some circumstances.ektus wrote:In my case, it doesn't work this way as has been discussed earlier in this thread. I tried it again today with the version below, still the same problem. The errors go away and the self test completes without errors if I rename the "FreeCAD 0.14" folder inside "Program Files", create a new folder with that same name there and place the three main folders from the dev snapshot inside. The 3D mouse still doesn't work, though.saso wrote:please note, this are development test builds. you should be able to run them by simply extracting the archive (7z) and run the FreeCAD.exe inside the bin folder. there is no install. you don't have to copy it (the extracted folders and files) to any special place, you can keep it on the desktop if you like. you don't have to replace your existing FreeCAD installation. just extract and run.
Regards
Ektus.
OS: Windows 7
Version: 0.15.4346 (Git)
Hash: e329cb5c3acd5b170359e0e8cd28d98b61be935d
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
