Attached is an example where some properties of the part are calculated.sgrogan wrote:Ca someone give me examples with this simple file.
Eivind
Use SpreadsheetMod2, as that's the one that I'm keeping updated. SpreadsheetMod3 is meant for merging, and will be squashed. It is slightly out of date.sgrogan wrote:@Eivind
Shoulf I be using SpreadsheetMod2 or SpreadsheetMod3 to see if this still compiles on Windows after your latests updates.
Great Job! I hope it makes it into 0.15
Hi,wmayer wrote:I agree with Yorik not to merge the spreadsheet module before the 0.15 release. Since it makes some major changes in the core system it may cause some unforeseeable regressions. That's why I prefer to have a longer test phase. So we can actually merge it as soon as 0.15 is out.
About the current spreadsheet workbench I have no strong opinion whether to release with 0.15 or not.
I completely agree. Maybe we should even rename python Spreadsheet module to prevent getting confused with the later c++ based module.rockn wrote:I mean a WB "installed" by hand in Mod directory
