Extrude from curved surface of cylinder
mario52
Re: Extrude from curved surface of cylinder
Post by mario52 »
hi alls
corrected
thank you for the report
texte = unicode(self.textEdit.toPlainText())
App.Console.PrintMessage(u"texte         " + unicode(texte)+"\n")
the macro Macro_FCCircularText.FCMacro
EDIT 15/05/2015 20h34 Paris
replace link to github
mario
Post by NormandC »
Hello Mario,
I'm still getting an error with your macro on Ubuntu 14.04.
New Font /usr/share/fonts/truetype/ubuntu-font-family/Ubuntu-M.ttf
  File "/home/normand2/Dessins/Macros_FreeCAD/Macro_FCCircularText.FCMacro", line 1277, in on_PU_Execute
    ss=Draft.makeShapeString(String=texte[ii2],FontFile=PolicePath,Size=SizeCaractere,Tracking=0)
  File "/usr/lib/freecad/Mod/Draft/Draft.py", line 2413, in makeShapeString
    obj.FontFile = FontFile
TypeError: Property 'FontFile': type must be str or unicode, not QString
mario52
Post by mario52 »
hi
tanks for reply
home no error (Ubuntu usb key)
OS: Ubuntu 14.10
Word size: 32-bit
Version: 0.14.3702 (Git)
Branch: releases/FreeCAD-0-14
Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406
Python version: 2.7.8
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.0
the error give one str or unicode i replace texte[ii2] to unicode(texte[ii2])
try to replace the line 1277 with this line for testing
voulez vous remplacer la ligne 1277 par cette ligne pour essayer
                    ss=Draft.makeShapeString(String=unicode(texte[ii2]),FontFile=PolicePath,Size=SizeCaractere,Tracking=0)
mario
mario52
Post by mario52 »
hi
I tried with this version and no problem with or not modify but FreeCAD 0.14.2935 (Git) (with
this is your version of Linux ?
OS: Ubuntu 14.04.1 LTS
Platform: 32-bit
Version: 0.14.2935 (Git) ???
Hash: eab159b6ee675012bf79de838c206a311e911d85
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.7.0
have you tried with the modification ?
mario
mario52
Post by mario52 »
hi
ver 0.13 09/08/2016
wiki Macro_Circular_Text
download the macro to gist Macro_FCCircularText.FCMacro
EDIT 21/08/2016 17h08 Paris
mario
Post by NormandC »
mario52 wrote:I tried with this version and no problem with or not modify but FreeCAD 0.14.2935 (Git) (with
Mario,
I'm maintaining the Daily Builds and Stable Releases PPA, and I wrote the "Please read first" topic (and its French counterpart). Why would you think I would use that utterly obsolete, badly packaged and buggy development version from the Ubuntu repository? I spend much of my time here telling newcomers to stop using that POS version which should have never been added to the Ubuntu repo in the first place...
But I should have posted my FreeCAD info nonetheless, so I guess I'm the one to blame. ;)
I had this error both with the latest 0.15.4671 release and the 0.16 development snapshot.
OS: Ubuntu 14.04.2 LTS
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Version: 0.16.4928 (Git)
Hash: d8f63bcfd10301f3d1e141cced4370f0782238d0
Qt version: 4.8.6
With your latest change, the macro won't even load its window.
<unknown exception traceback><type 'exceptions.SyntaxError'>: ("(unicode error) 'utf8' codec can't decode byte 0xb0 in position 0: invalid start byte", ('/home/normand2/Dessins/Macros_FreeCAD/Macro_FCCircularText.FCMacro', 621, None, 'self.DS_InclinaisonX.setSuffix(" X\xb0")\n'))
If I change my macro path to ~/.FreeCAD/Macros, same error:
<unknown exception traceback><type 'exceptions.SyntaxError'>: ("(unicode error) 'utf8' codec can't decode byte 0xb0 in position 0: invalid start byte", ('/home/normand2/.FreeCAD/Macros/Macro_FCCircularText.FCMacro', 621, None, 'self.DS_InclinaisonX.setSuffix(" X\xb0")\n'))
When I open your macro with a text editor, I'm getting a warning:
mario52
Post by mario52 »
hi
hi
I work with Ubuntu http://www.linuxliveusb.com/ USB key if I use the live mode, I do not know how to update so I do with the backup versions that work with permanently fixed otherwise it is nothing sorry !!
For your new mistake you can replace lines 621,622,623 by those below
         self.DS_InclinaisonX.setSuffix (unicode ("X°"))
         self.DS_InclinaisonY.setSuffix (unicode ("Y°"))
         self.DS_InclinaisonZ.setSuffix (unicode ("Z°"))
if there is still a mistake you can comment on these only serve to show the degree sign "°" and I do not understand because it has nothing to do with my last modification
Please tell me what I calquerai my macro on the changes it is for me the only method thank you
mario
_________________________________________________________
pour Ubuntu je travaille avec http://www.linuxliveusb.com/ sur clef USB si j'utilise le mode live , je ne sais pas faire de mise à jour donc je fais avec les versions avec sauvegarde permanantes qui fonctionnent sinon c'est rien du tout désolé !!
Pour votre nouvelle erreur vous pouvez remplacer les lignes 621, 622, 623 par celles ci
        self.DS_InclinaisonX.setSuffix(unicode(" X°"))
        self.DS_InclinaisonY.setSuffix(unicode(" Y°"))
        self.DS_InclinaisonZ.setSuffix(unicode(" Z°"))
s'il y a encore une erreur vous pouvez les commenter elles ne servent qu'a afficher le signe degré "°" et je ne comprends pas car ça n'a rien à voir avec ma dernière modification
SVP dites moi quoi et je calquerai ma macro sur vos modifications c'est pour moi la seule méthode merci[/i]
EDIT: PS pour l'éditeur de texte sélectionnez un autre codage que utf8
mario
Post by NormandC »
mario52 wrote:For your new mistake you can replace lines 621,622,623 by those below
Thanks Mario, to paraphrase your macro's default text: you're the best! :D
But I also needed to change lines 603 and 605:
            MainWindow.setWindowFlags(PyQt4.QtCore.Qt.WindowStaysOnTopHint)        # PyQt4 cette fonction met la fen\EAtre en avant
        except Exception:
            MainWindow.setWindowFlags(PySide.QtCore.Qt.WindowStaysOnTopHint)       # PySide cette fonction met la fen\EAtre en avant
And replace "\EA" with "ê". In Gedit (Ubuntu's text editor), those codes were highlighted in red like those for the degree symbol.
This fixed the macro for me, and Gedit now opens the macro without errors.
mario52 wrote:I work with Ubuntu http://www.linuxliveusb.com/ USB key if I use the live mode, I do not know how to update
If you created your LibeUSB key in persistent mode, you should be able to do software updates just like a regular install. Then it's just a matter of adding either of the FreeCAD PPA (Stable or Daily) to your software sources. After that you can open the Update Manager (Gestionnaire de mises à jour) to update your software packages. But I haven't used a LiveUSB in a long time.
mario52
Post by mario52 »
hi
NormandC wrote:If you created your LibeUSB key in persistent mode, you should be able to do software updates just like a regular install. Then it's just a matter of adding either of the FreeCAD PPA (Stable or Daily) to your software sources. After that you can open the Update Manager (Gestionnaire de mises à jour) to update your software packages. But I haven't used a LiveUSB in a long time.
that's exactly what I do et ça fonctionne très bien (an updated take much time)
I iron my macros and remove all accents
je vais repasser tutes mes macros et supprimer les accents
PS :
NormandC wrote:When I open your macro with a text editor, I'm getting a warning:
Theoretically this is a file to be opened in a Python environment for other publishers must follow the rules of the editor used (select the right encoding)
théoriquement c'est un fichier qui doit être ouvert dans un environnement Python , pour les autres éditeurs il faut suivre les règles de l'éditeur utilisé (sélectionner le bon encodage)
EDIT 15/05/2015 20h51 Paris
paste the link to github
merci pour vos tests
mario
orionstars
Post by orionstars »
Does this macro work if FreeCAD 0.15 is running on Mac 10.10.5?
