PrzemoF wrote:Can you post the path you have in FEM preferences for ccx binary and the result of "file" for that ccx binary?
sh: 1: SMDS_MemoryLimit: not found
Using ccx binary path from FEM preferences: /usr/local/CalculiX/ccx_2.8p2/src/ccx_2.8p2
FemConstraintForce
No Line Loads or Point Loads in the model
FemConstraintForce, AreaLoad on faces, CLOAD is used
force_per_sum_ref_face_area: 0.1
Part__Feature.Face4 sum_node_areas 10000.0 ref_face.Area: 10000.0
runCalculix
run Calculix at: /usr/local/CalculiX/ccx_2.8p2/src/ccx_2.8p2 with: /home/j-btw/FreeCAD/FEM/Part__Feature_Mesh
calculixStarted()
PySide.QtCore.QProcess.ProcessState.Running
calculixFinished()127
PySide.QtCore.QProcess.ProcessState.NotRunning
Loading results....
j-btw@jbtw-Ubuntu:~$ ls -l /usr/local/CalculiX/ccx_2.8p2/src/ccx_2.8p2
-rwxr-xr-x 1 j-btw users 5412993 mrt 4 19:49 /usr/local/CalculiX/ccx_2.8p2/src/ccx_2.8p2
j-btw@jbtw-Ubuntu:~$ file /usr/local/CalculiX/ccx_2.8p2/src/ccx_2.8p2
/usr/local/CalculiX/ccx_2.8p2/src/ccx_2.8p2: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.4, not stripped
