FindNETGEN rework
sgrogan
Re: FindNETGEN rework
Postby sgrogan » Tue Jul 21, 2015 12:17 am
Fat-Zer wrote: I don't know a lot about windows build... could you link me to some notes what netgen package looks like there.
Also could you provide CMakeCache.txt and CMakeFiles/CMakeError.log to see what gone wrong...
There's no url to the contents of the libacks, per sey.On Windows it's not necessary to have a compiled NETGEN. From the the libpack we use nglib. I believe there is a .dll in\bin, plus /netgen + /lib and + /include sub-directories. I'll try to make this understandable and post back.
CMakeCache.txt
(131.26 KiB) Downloaded 27 times
CMakeOutput.log
(22.26 KiB) Downloaded 24 times
CMakeError.log
(20.95 KiB) Downloaded 22 times
"fight the good fight"
django013
Postby django013 » Tue Jul 21, 2015 3:59 am
It's true only if package provides version information somehow, e.g. via pkg-config
Ok, on debian based systems, you can query version information for each officially installed package with dpkg:
dpkg -l | grep <package-name>
A complete commandline to get the version of developer library of i.e. libavcodec looks like:
dpkg -l | grep libavcodec-dev | head -1 | awk '{ print $3; }'
... by the way: netgen provides version informations in CMakeLists.txt in root directory
if(NOT CMAKE_BUILD_TYPE)
    set(CMAKE_BUILD_TYPE "RelWithDebInfo" CACHE STRING INTERNAL)
endif(NOT CMAKE_BUILD_TYPE)
cmake_minimum_required(VERSION 2.8.9)
project(Netgen)
set(NETGEN_VERSION_MAJOR 6)
set(NETGEN_VERSION_MINOR 1)
set(NETGEN_VERSION "${NETGEN_VERSION_MAJOR}.${NETGEN_VERSION_MINOR}-dev")
set(PACKAGE_VERSION "${NETGEN_VERSION}")
... so version information could be obtained with grep
Sad to say - netgens executable is a poor one. It does not support the standard version query like "netgen --version"
OS: Linux Debian Jessie amd64 - FC: Git Master
Fat-Zer
Postby Fat-Zer » Wed Jul 22, 2015 9:23 pm
sgrogan, thanks for your input... It will be helpfull...
Ok, There is one pretty easy to fix:
cl /c /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\occ /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\general /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\meshing /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\linalg /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\lib\cmake\..\..\include\oce /Zi /W3 /WX- /Od /Ob0 /D WIN32 /D _WINDOWS /D NETGEN_WITH_OCC /D _DEBUG /D NO_PARALLEL_THREADS /D OCCGEOMETRY /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Fo"cmTryCompileExec2733992907.dir\Debug\\" /Fd"cmTryCompileExec2733992907.dir\Debug\vc120.pdb" /Gd /TP /errorReport:queue "C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\src.cxx"
"C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\cmTryCompileExec2733992907.vcxproj" (default target) (1) ->
  c:\users\chris\desktop\fclibs_vc12_x64\freecadlibs_11.1_x64_vc12\include\netgen\general\gzstream.h(35): fatal error C1083: Cannot open include file: 'zlib.h': No such file or directory [C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\cmTryCompileExec2733992907.vcxproj]
    0 Warning(s)
    1 Error(s)
Time Elapsed 00:00:00.57
Source file was:
#include <occgeom.hpp>
    int main() { netgen::OCCGeometry foo; }
It just requires zlib... don't know if it will require link to the dll, but yet another find_package() should fix this issue... But I suppose it will break on the the second one issue like two other tests.
But I don't really know what to do with this one:
ClCompile:
  C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\x86_amd64\CL.exe /c /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\general /Zi /W3 /WX- /Od /Ob0 /D WIN32 /D _WINDOWS /D NETGEN_WITH_PARALLEL_THREADS /D _DEBUG /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Fo"cmTryCompileExec2620214328.dir\Debug\\" /Fd"cmTryCompileExec2620214328.dir\Debug\vc120.pdb" /Gd /TP /errorReport:queue "C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\src.cxx"
  Microsoft (R) C/C++ Optimizing Compiler Version 18.00.31101 for x64
  Copyright (C) Microsoft Corporation.  All rights reserved.
  cl /c /IC:\Users\Chris\Desktop\FClibs_vc12_x64\FreeCADLibs_11.1_x64_VC12\include\netgen\general /Zi /W3 /WX- /Od /Ob0 /D WIN32 /D _WINDOWS /D NETGEN_WITH_PARALLEL_THREADS /D _DEBUG /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /EHsc /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /GR /Fo"cmTryCompileExec2620214328.dir\Debug\\" /Fd"cmTryCompileExec2620214328.dir\Debug\vc120.pdb" /Gd /TP /errorReport:queue "C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\src.cxx"
  src.cxx
C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\atlmfc\include\afx.h(24): fatal error C1189: #error :  Building MFC application with /MD[d] (CRT dll version) requires MFC shared dll version. Please #define _AFXDLL or do not use /MD[d] [C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\cmTryCompileExec2620214328.vcxproj]
Done Building Project "C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\cmTryCompileExec2620214328.vcxproj" (default targets) -- FAILED.
Build FAILED.
"C:\Users\Chris\GitHub\Find-Netgen-build\CMakeFiles\CMakeTmp\cmTryCompileExec2620214328.vcxproj" (default target) (1) ->
(ClCompile target) ->
    0 Warning(s)
    1 Error(s)
Time Elapsed 00:00:00.43
Source file was:
 #include <myadt.hpp>
    int main() { netgen::NgMutex foo; }
can somebody point me out whay should I include/define to make the /MDd happy? may be it will be enough to just define _AFXDLL? may it be empty?
I suppose /MDd should be there itself because there are other tests built well with it...
//Path to a library.
NETGEN_LIBRARY_mesh:FILEPATH=NETGEN_LIBRARY_mesh-NOTFOUND
NETGEN_LIBRARY_occ:FILEPATH=NETGEN_LIBRARY_occ-NOTFOUND
Are there any *{occ,mesh}.{lib,dll} in your netgen distribution? Is it version 5+?
sgrogan
Postby sgrogan » Thu Jul 23, 2015 1:44 pm
According to the build script it should be 5.1
https://github.com/peterl94/clbundler-f ... /netgen.py
In
LibPack/bin/ there is nglib.dll
In
Libpack/include/netgen/csg
Libpack/include/netgen/meshing
Libpack/include/netgen/occ
etc.
These directories contain only header files (.hpp)
In
Libpack/lib/ there is nglib.lib
Fat-Zer
Postby Fat-Zer » Fri Aug 07, 2015 5:21 pm
Sorry, that I haven't replied for a while...
I can't fix the test code compilation on MSVC, so I've just disabled it... that should be enough to make it work... please check...
django013 wrote:Ok, on debian based systems, you can query version information for each officially installed package with dpkg:
It's not an option to query package manager from cmake...
django013 wrote:... by the way: netgen provides version informations in CMakeLists.txt in root directory
first, it's only for version six, which is not released yet (at least there is no stable release), 5.x still uses autotools, secondly the CMakeLists.txt is not being installed to the system... so unless upstream will provide it's own FindNETGEN module it's useless...
django013 wrote:Sad to say - netgens executable is a poor one. It does not support the standard version query like "netgen --version"
even if it were, we couldn't lay on that this executable is installed on the building system due to freecad doesn't depends upon netgen itself, but only on the nglib...
sgrogan
Postby sgrogan » Sat Aug 08, 2015 3:09 pm
Every thing appears to be OK on win.
OS: Windows 7
Version: 0.16.5240 (Git)
Branch: FindNETGEN-rework
Hash: f97593084e371ef2eeec15b0ed56cd41afd033c9
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Fat-Zer
Postby Fat-Zer » Mon Aug 10, 2015 5:13 pm
Thanks, for testing...
I'll wait for some time if there will be some positive or negative feedbacks from mingw or mac users... And if there won't be any I'll pull-requst...
Postby wmayer » Tue Aug 11, 2015 8:59 am
Could you postpone this until Friday next week or so?
Fat-Zer
Postby Fat-Zer » Tue Aug 11, 2015 11:07 am
wmayer wrote:Could you postpone this until Friday next week or so?
sure, no hurry here...
PrzemoF
Postby PrzemoF » Thu Aug 27, 2015 12:52 pm
I can't (was: can) wait to start building FreeCAD rpm packages from the master branch for fedora witn netgen switched on 8-)
Edit: Thanks wmayer for catching the typo!
