Python bindings for Surface WB
Chris_G
Post by Chris_G »
I would like to give a try at adding python bindings to Surface workbench.
Some people sometimes want to access the surface tools from python.
And it would add flexibility, making it a hybrid C++ / python workbench.
After a little web search, I saw that there are several solutions available.
The one that seems to be already used in FreeCAD are :
- pybind11
- boost.python
- PyCXX (not sure about this one, but I think I saw this name several times ???)
- custom FreeCAD bindings, like in the Part module, and looking much like this.
I am used to the Part module solution, but it is quite a lot of code writing.
So, I would like to have advise from skilled developers.
Thanks in advance.
Gift
Re: Python bindings for Surface WB
Post by Gift »
Hello Chris,
it is possible the use pythonocc-core now with conda. [1]
[1] https://forum.freecadweb.org/viewtopic. ... 62#p425495
kind regards
openBrain
Post by openBrain »
Chris_G
Post by Chris_G »
Gift wrote: Sat Sep 19, 2020 3:26 pm it is possible the use pythonocc-core now with conda. [1]
Thanks,
This look like a good OCC testing / exploring solution, but not really suited for python bindings inside FreeCAD master.
And I have not been able to build it from AUR on Manjaro Linux :oops:
openBrain wrote: Sat Sep 19, 2020 3:54 pm Maybe this can be of help: https://forum.freecadweb.org/viewtopic.php?f=10&t=43316
Thanks, maybe this will be of help, if the same python binding generator is chosen.
vocx
Post by vocx »
Chris_G wrote: Sat Sep 19, 2020 2:15 pm ...
I found this historical thread, How these things work together.
Unfortunately, it's unclear if the situation has changed a lot in 10 years or not. It seems to me that manual wrapping is still the norm, and I don't quite see where PyCXX and pybind11 are used. I think pybind11 is used at least in the Mesh Workbench with a couple of commands, surface flattening, (boost-python deprecated?).
This is the most recent thread I can think about, [How to ?] Expose C++ functions to FreeCAD Python API.
Chris_G
Post by Chris_G »
vocx wrote: Sat Sep 19, 2020 4:21 pm I found this historical thread, How these things work together.
Interesting reading.
vocx wrote: Sat Sep 19, 2020 4:21 pm Unfortunately, it's unclear if the situation has changed a lot in 10 years or not.
That's why I wanted to dip a toe in the water, first ;)
Cyril
Post by Cyril »
pybind11 is relatively easy and apparently very good. python-occ-core and ifcopenshell use swig which looks awful. Also there is one like more like pybind made by Qt guys. See Cristián Maureira-Fredes - Unleash the power of C++ in Python and Talk: Dr. Cristián Maureira-Fredes - C++ ♥ Python: from modules to hybrid applications there also some talks specific about pybind.
I blog about HVAC / BIM / Energy : pythoncvc.net. If you like you can follow the RSS feed.
vanuan
Post by vanuan »
Chris_G wrote: Sat Sep 19, 2020 4:17 pm And I have not been able to build it from AUR on Manjaro Linux
The most reliable way to build it is to use Docker: https://wiki.freecadweb.org/Compile_on_Docker
It takes some time to get used to but after you learn it you would forget you ever had any issues with development dependencies.
Chris_G
Post by Chris_G »
Cyril wrote: Sat Sep 19, 2020 8:42 pm pybind11 is relatively easy and apparently very good.
It seems to be a good candidate, along with FreeCAD custom one.
vanuan wrote: Sun Sep 20, 2020 2:37 am The most reliable way to build it is to use Docker: https://wiki.freecadweb.org/Compile_on_Docker
I was talking about pythonocc. FreeCAD builds flawlessly.
Cyril
Post by Cyril »
Chris_G wrote: Sun Sep 20, 2020 7:26 amI was talking about pythonocc. FreeCAD builds flawlessly.
See this issue : https://github.com/tpaviot/pythonocc-co ... -683884628 I personally just rolled back to OCC previous version.
Also, you don't need to build python-occ-core from AUR, it is in community packages : https://www.archlinux.org/packages/comm ... -occ-core/
