Error while configuring cmake
- DeepSOIC
Re: Error while configuring cmake
Just got a successful compile on Windows. I had installed PySide (which was quite a bit of trouble to do, I can share what I did to achieve that if anyone is interested). Looking forward to seeing frustration free new libpack!!!
I am cloning Perterl94's branch now to try out the new libpack 9.xDeepSOIC wrote:Just got a successful compile on Windows. I had installed PySide (which was quite a bit of trouble to do, I can share what I did to achieve that if anyone is interested). Looking forward to seeing frustration free new libpack!!!
I got scared when I started looking at installing Pyside myself. If this doesn't workout I may take you up on your offer.
Cheers
"fight the good fight"
- DeepSOIC
Here it goes. EDIT - there is something wrong! Please don't follow!
- Install python 2.7.8 64 bit (the python bundled with libpack didn't work for me). Make sure the newly installed python is invoked when you type "python" into console. (type python <enter> import sys <enter> sys.executable <enter>, you'll see where the interpreter is located)
- Install PySide by following the instructions on this page:
http://qt-project.org/wiki/PySide_Binaries_Windows
You will have to install pip first (pip is a package manager for python). There are instructions on the mentioned page. After you have done so, you can find pip.exe in C:\path\to\python\scripts\pip.exe. - Once PySide is installed, open CMakeCache.txt and point it to pyside tools:
//Path to a program.
PYSIDERCC4BINARY:FILEPATH=C:/Python27/Lib/site-packages/PySide/pyside-rcc.exe
PYSIDEUIC4BINARY:FILEPATH=C:/Python27/Scripts/pyside-uic.exe - rerun CMake to be sure, build!
- DeepSOIC
Hmm... It worked... I had a successful build for release... Started a debug build, and somewhere near the end of the build I got a BSOD . Now, after a reboot, I get strange looking python related errors when running CMake. WHATTHA?? Sorry for offtopic...
