Import Tool Table
XXX
Import Tool Table
Post by XXX » Sun May 29, 2016 8:28 pm
Hi Folks,
Can someone point me in the correct direction on how to "Import Tool Table" please.
I have a LinuxCNC tool table (.tbl) that as I understand should be importable.
Thanks, X
sliptonic
Re: Import Tool Table
Post by sliptonic » Sun May 29, 2016 10:15 pm
It's not possible to directly import a linuxcnc tool table yet. Only importers for XML and Heekscnc's format have been written.
It should be pretty easy to write a handler for linuxcnc and would be gratefully accepted. Everything should be in the file /Mod/Path/PathScripts/ToolTableEditor.py
XXX
Post by XXX » Sun May 29, 2016 11:02 pm
Thanks for the response.
As I've shared in the past, I'm the last person you would want tinkering with a program.
But, I have a little time this Holiday weekend so I'll see if I can make myself useful for a change.
(I can't make any promises, wish I could).
yorik
Site Admin
Post by yorik » Mon May 30, 2016 1:32 pm
Can you attach here one of those .tbl files so we can have a look?
terrym
Post by terrym » Thu Oct 22, 2020 12:59 am
Here is a copy of my tool.tbl, renamed to .txt so as to be able to upload it...
tool.txt
Rename to tool.tbl
(2.8 KiB) Downloaded 12 times
terrym
Post by terrym » Thu Oct 22, 2020 1:06 am
Looking at 0.19 it seems the file mentioned above by sliptonic is gone and there are now two files of interest?
PathToolLibraryEditor.py
PathToolLibraryManager.py
terrym
Post by terrym » Thu Oct 22, 2020 1:12 am
