From the FreeCAD Python console: Python 3.6.8 (default, Aug 20 2019, 17:12:48)
When I try to create a 3D surface path (which I've done before) using FreeCAD Ver 0.18.3, I get the following error and no path is generated:
In FreeCAD Daily, when I try to switch to the Path workbench, I get a pop-up stating "cannot import name 'PathToolLibraryEditor' and the following errors:PathOpGui.INFO: Title: 'Surface'
Surfacing Select Mode
Free Select
StepOver is 80
base object: Clone
File "/usr/share/freecad/Mod/Path/PathScripts/PathUtils.py", line 61, in new_function
res = function(*args, **kwargs)
File "/usr/share/freecad/Mod/Path/PathScripts/PathOp.py", line 477, in execute
result = self.opExecute(obj)
File "/usr/share/freecad/Mod/Path/PathScripts/PathSurface.py", line 162, in opExecute
output = self._dropcutter(obj, s, bb)
File "/usr/share/freecad/Mod/Path/PathScripts/PathSurface.py", line 308, in _dropcutter
for n in xrange(0, Nx):
<class 'NameError'>: name 'xrange' is not defined
I haven't deleted anything from any of the paths and am not versed at all in python to troubleshoot on my own - any suggestions?cannot import name 'PathToolLibraryEditor'
File "<string>", line 75, in Initialize
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathGuiInit.py", line 80, in Startup
from PathScripts import PathToolLibraryEditor
Thanks
