Profile Expand / Offset
- dubstar-04
What is the purpose / use case for the expand vs offset properties of the profile operation?
Wiki Entry:
Thanks,
Dan
Wiki Entry:
Thanks,
Dan
- dubstar-04
Re: Profile Expand / Offset
If I try and use the expand profile property I get the following error:
Steps to reproduce:
- Deselect all geometry
- Select profile operation
- Press apply
- Press ok
- Select the profile operation the the job tree
- Change the value of the expand profile property in the data tab
Can anyone replicate?
Thanks,
Dan
OS: Debian GNU/Linux 10 (buster) (GNOME/gnome-xorg)
Version: 0.19.23700 +7 (Git)
Build type: Unknown
Branch: pr/4278
Hash: c434ee34a724c1dec1b79fa0c499a3c0ec15aeb3
Python version: 3.7.3
Qt version: 5.11.3
File "/home/sandal/Documents/GitHub/FreeCAD/build/Mod/Path/PathScripts/PathOp.py", line 526, in execute
result = self.opExecute(obj) # pylint: disable=assignment-from-no-return
File "/home/sandal/Documents/GitHub/FreeCAD/build/Mod/Path/PathScripts/PathAreaOp.py", line 394, in opExecute
aOS = self.areaOpShapes(obj) # pylint: disable=assignment-from-no-return
File "/home/sandal/Documents/GitHub/FreeCAD/build/Mod/Path/PathScripts/PathProfile.py", line 530, in areaOpShapes
shapes.extend(self._processEachModel(obj))
File "/home/sandal/Documents/GitHub/FreeCAD/build/Mod/Path/PathScripts/PathProfile.py", line 699, in _processEachModel
shapeEnv = self._getExpandedProfileEnvelope(obj, eSlice, False, obj.StartDepth.Value, obj.FinalDepth.Value)
File "/home/sandal/Documents/GitHub/FreeCAD/build/Mod/Path/PathScripts/PathProfile.py", line 655, in _getExpandedProfileEnvelope
offsetVal = calculateOffsetValue(obj, isHole)
File "/home/sandal/Documents/GitHub/FreeCAD/build/Mod/Path/PathScripts/PathProfile.py", line 641, in calculateOffsetValue
offset = obj.OffsetExtra.Value + self.tool.Diameter
<class 'ArithmeticError'>: {'sclassname': 'N4Base18UnitsMismatchErrorE', 'sErrMsg': 'Quantity::operator +(): Unit mismatch in plus operation', 'sfile': '', 'iline': 0, 'sfunction': '', 'swhat': 'Quantity::operator +(): Unit mismatch in plus operation', 'btranslatable': False, 'breported': True}
Steps to reproduce:
- Press apply
- Press ok
Thanks,
Dan
Build type: Unknown
Branch: pr/4278
Qt version: 5.11.3
- dubstar-04
Test file attached
- ProfileTest.FCStd
- (16.17 KiB) Downloaded 47 times
PR #4270, Path: Profile Op - Fix `Expand Profile` feature; include some code cleanup
Closed.
Russell
Closed.
Russell
- dubstar-04
Hi Russ,
Thanks for the reply. What was the reason for closing the PR?
Thanks,
Dan
Thanks,
Dan
I re-opened the PR because I think it should be fixed regardless of the fate of this feature. I intend to use it and I think others will get some use out of it. Also, if the feature will be live in 0.19, it ought to be working without this error.
Russell
Russell
- dubstar-04
Thats great news Russ!
Thank you,
Dan
Not any more. Pie in my face and the feature being removed prior to 0.19 release. That clarification I was lacking was delivered.
PR #4333, [Path] Remove `Expand Profile` feature from Profile op
Neither "cheers" nor "cheerio" seem appropriate after such a press release.
Hope your weekend is sunny and warm. Thanks for the support, sir. Keep those successive Profile ops in a macro.
Russell
- dubstar-04
Has there been discussion regarding this feature?Russ4262 wrote: ↑Sat Jan 30, 2021 2:29 amNot any more. Pie in my face and the feature being removed prior to 0.19 release. That clarification I was lacking was delivered.
Russell
Thanks,
Dan
There has been, and it wasn't fair (to Russell) at all not to have that discussion in public. I am the one who deserves the cake in the face (and much more). While Russ' feature is extremely useful, I don't think it belongs into Profile, which is the contentious point here. And while I did discuss this with Russell I neglected to clarify that it needs to be cleaned up for 0.19
I realise that this comes as a big disappointment to all, especially Russell - so I would like to elaborate on the reasoning. A "Profile" is an op which follows a line, be that an explicit line in the form of some connected edges or the envelope wire of a face/solid. And that is all a Profile op should ever do. The "Expand" feature however makes the Profile op behave like a Pocket op and one might wonder - why do I need two ops when both of them do the same thing anyway. The moment we're talking about clearing an "area", it's not a "Profile" anymore (IMHO).
Now FC (hopefully) is close to a release which has a considerable impact on the importance, or the weight of above reasoning. If we were to ship this feature in 0.19 as part of the Profile op it becomes very hard to remove that feature in a subsequent release. Users who would use it in 0.19 would rightfully complain about it not being there in 0.20.
Let me make this very clear, the functionality of what Russell implemented is awesome, and nobody questions the need for that functionality - the only question is where and when.
Final note: if all of this makes you angry - don't hold back, it'll have an impact on what happens in 0.20, and when.
