Hello folks,
I would like to cut some slots on the side of a raw stock of Delrin material to test the quality of some end-mills.
I quickly faced one problem: I was not able to make mill-bit "entering" into the stock from the side. I could achieve that???
I looked at the good video from sliptonic, but setting the start point just provides an initial point for the first movement, not for all layers to be milled down.
I other words, I would like to obtain a movement as depicted in the attached image (for all of the layers).
Any clue?
OS: Ubuntu 16.04.7 LTS (XFCE/xfce)
Version: 0.19.22846 (Git) AppImage
Hash: 1f46b72491a0008384a6db4f2615a656249f6f08
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
How to "enter" in the raw stock from the side of it?
- Selection_7158.jpg (44.13 KiB) Viewed 523 times
- dubstar-04
Re: How to "enter" in the raw stock from the side of it?
Could you share your file?
Thanks,
Dan
Thanks,
Dan
One momeeeeeent!.....
Here we are.
Here we are.
- Schneider-test-01.FCStd
- (46.44 KiB) Downloaded 33 times
P.S.
I checked the generated gcode. The mill-bit is not entering from the side of the stock even by setting the start point in the operation properties.
Try Lead In Out dressup
- dubstar-04
