Pull Request for adding GDML Workbench to AddonManager
keithsloan52
Post by keithsloan52 »
Have added icon and updated qc file, but pull request seems to be being blocked as previous request about PLY has not completed.
What should I do?
keithsloan52
Re: Pull Request for adding GDML Workbench to AddonManager
Pull request looks like
Is it stuck behind #2904 removing PLY
vocx
Post by vocx »
keithsloan52 wrote: Fri Jan 24, 2020 2:38 pm What should I do?
You have to wait until Yorik decides to merge it.
