[retracted] PR 3737 - don't show by default report view for warnings
vocx
Re: PR 3737 - don't show by default report view for warnings
Post by vocx »
uwestoehr wrote: Sun Jul 26, 2020 12:06 pm ...
For her the file works, so why is she by default forced to see detail stuff not necessary for her real task (in this case to print the part as soon as possible)?
I think in this case, the warning message itself is justified, because when "Links go outside the scope" you should be warned.
However, in this case the problem should be solved in the PartDesign Workbench because clearly you aren't doing something wrong in the model. So, it's a combination of two things, the warning is thrown unnecessarily, and second, the warning makes the report window open, which should probably not occur.
uwestoehr
Post by uwestoehr »
vocx wrote: Sun Jul 26, 2020 10:11 pm and second, the warning makes the report window open, which should probably not occur.
Yes, and this is all my PR does.
The other issue needs to be addressed separately.
TheMarkster
Post by TheMarkster »
IMO, the default should be set to true specifically to benefit new users. Those who are annoyed can disable the preference.
TheMarkster
Related PR: https://github.com/FreeCAD/FreeCAD/pull/3754
This adds the preferences to the right-click context menu of the report view.
Snip macro screenshot-dbd7ef.png (31.63 KiB) Viewed 1599 times
Founder
Post by wmayer »
IMO, the context-menu looks a bit messy and it's not immediately clear what the difference is between "Logging" and "Show on Logging", etc.
Maybe it's easier to create a sub-menu "Show report view" and move the "Show ..." actions there -- but dropping the two words "Show on"
openBrain
Post by openBrain »
Agree with @wmayer.
Maybe also the simple "Logging", "Warning", "Error" could be respectively replaced by "Display log messages", "Display warning messages", "Display error messages". These 3 could also be grouped in a submenu.
Also the "Show on" could be clearer being "Expand on" (but hey, I'm not native english speaker :D)
TheMarkster
Snip macro screenshot-1fc615.png (28.09 KiB) Viewed 1543 times
Snip macro screenshot-3c2246.png (26.46 KiB) Viewed 1543 times
openBrain
Post by openBrain »
TheMarkster wrote: Wed Jul 29, 2020 2:26 am
:+1:
