non uniform distributed load
UR_
Re: non uniform distributed load
Post by UR_ »
You are right, i noticed this too.
I think major waste of time is object adding (to tree).
I will have a look at curveWB, perhaps i can find the place where Chris_G does the magic. :roll:
Chris_G wrote:ping
@Chris_G, can we please have a hint from Premier League :?
Chris_G
Post by Chris_G »
UR_ wrote: Wed May 02, 2018 7:45 pm I think major waste of time is object adding (to tree).
you will probably get much faster rendering by adding directly your stuff in the coin SceneGraph().
Here is an example :
import FreeCAD
from FreeCAD import Vector
import Part
from pivy import coin
NUM = 10
# create a sample curve
poles0 = [Vector (-2.207077980041504, -0.4698541462421417, 0.0), Vector (-1.3755598068237305, 1.137541651725769, 0.0), Vector (0.10200775414705276, 1.2364583015441895, 0.0), Vector (1.397197961807251, -0.0834609717130661, 0.0)]
weights0 = [1.0, 1.0, 1.0, 1.0]
knots0 = [0.0, 1.0]
mults0 = [4L, 4L]
periodic0 = False
degree0 = 3
rational0 = False
bs0 = Part.BSplineCurve()
bs0.buildFromPolesMultsKnots(poles0, mults0, knots0, periodic0, degree0)
obj0 = FreeCAD.ActiveDocument.addObject("Part::Spline","BSplineCurve0")
edge = bs0.toShape()
obj0.Shape = edge
# compute sample points
parameters = [float(i)/NUM for i in range(NUM+1)]
poc = [edge.valueAt(p) for p in parameters] # poc = points on curve
nor = [edge.valueAt(p)+edge.normalAt(p) for p in parameters] # nor = normals
# here is the coin stuff
coinVec = list()
indexes = list()
for i in range(NUM+1):
	coinVec.append(coin.SbVec3f(poc[i].x,poc[i].y,poc[i].z))
	coinVec.append(coin.SbVec3f(nor[i].x,nor[i].y,nor[i].z))
	indexes.extend([i*2,1+i*2,-1])
# indexes = [0, 1, -1, 2, 3, -1, 4, 5, -1, 6, 7, -1, 8, 9, -1, 10, 11, -1, 12, 13, -1, 14, 15, -1, 16, 17, -1, 18, 19, -1, 20, 21, -1]
# the -1 index value is a break in the polyline
node = coin.SoSeparator()
pts = coin.SoCoordinate3()
lineset = coin.SoIndexedLineSet()
node.addChild(pts)
node.addChild(lineset)
pts.point.setValues(0,len(coinVec),coinVec)
lineset.coordIndex.setValues(0,len(indexes),indexes)
sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
sg.addChild(node)
#sg.removeChild(node)
And here are my 2 favorite links about coin :
https://grey.colorado.edu/coin3d/annotated.html
http://www-evasion.imag.fr/Membres/Fran ... index.html
UR_
Post by UR_ »
Chris_G wrote: Wed May 02, 2018 9:26 pm Here is an example
Thanks!
Will have a look at this.
Thank you very much!
UR_
Post by UR_ »
[/quote]
thschrader wrote: Wed May 02, 2018 5:52 pm Is there a possibility to speed this up?
Now it's a little bit faster.
So no more coffee breakes! :lol:
ApplyNonUniformLoad.FCMacro
(7.84 KiB) Downloaded 80 times
hardcoded user input is presetted for example file from here:
https://forum.freecadweb.org/posting.ph ... 8#pr231275
@thschrader: Please don't overshoot :lol:
phpBB [video]
thschrader
Post by thschrader »
UR_ wrote: Sun May 06, 2018 5:21 pm @thschrader: Please don't overshoot :lol:
no problem... :)
Taufeeq2
Post by Taufeeq2 »
there is a routine here http://web.mit.edu/calculix_v2.7/Calcul ... de190.html
But i dont know how to incoporate it in freecad
Jee-Bee
Post by Jee-Bee »
*DLOAD is the presure constraint in FreeCAD. only when applaying non uniform distributed load load you have to use the script somwhere in this topic
thschrader
UR_ wrote: Sun May 06, 2018 5:21 pm Now it's a little bit faster.
Yep. Writing the load needs only seconds. Very nice!
Pep
Post by Pep »
Hey everyone,
I was trying to use this, since it would be extremely useful to me. However, when I run it, it computes as if there is no load distribution. The report contains the following errors:
Pressure on shell mesh at the moment only supported for meshes with appropriate group data.
PySide2.QtCore.QProcess.ProcessState.NotRunning
PySide2.QtCore.QRegExp('\*ERROR.*\n\n', 1, 0)
with only the first one being red. Anyone knows what is going wrong here?
bernd
Post by bernd »
would you send the file you tested with, a link to the code you used and you freecad version info. than we could try to reproduce your problem
