[Solved] FEM doesn't work anymore
Re: FEM doesn't work anymore
This has gotten fixed, at least on FreeBSD: https://www.freecadweb.org/tracker/view ... 984#c13224
I've checked at least some of the Path and FEM functions that create new dialogs, and so far everything has worked.
This is great. If someone could please provide the link to the git path, I would like to test it in linux.
Master branch until last try was still on 16117, so rebuilding it changed nothing.
- adrianinsaval
What do you mean? master is at 17068, 16117 is 0.18.2
In the link provided here there is mention of a git patch:
Don't know if it was incorporated in master yet. Hope it helps.denverh wrote: ↑Mon Jun 17, 2019 12:46 pm This has gotten fixed, at least on FreeBSD: https://www.freecadweb.org/tracker/view ... 984#c13224
When compiling with the mentioned patch I always get:
OS: Manjaro Linux (dwm/dwm)
Version: 0.19.17070 (Git)
Python version: 3.7.3
Qt version: 5.12.3
[ 70%] Linking CXX shared library ../../lib/libFreeCADGui.so !1347
/usr/bin/ld: CMakeFiles/FreeCADGui.dir/WidgetFactory.cpp.o: in function `convertWrapperToQuantity(PySide::PyObjectWrapper const&)':
WidgetFactory.cpp:(.text+0xcd): undefined reference to `PySide::PyObjectWrapper::operator _object*() const'
/usr/bin/ld: CMakeFiles/FreeCADGui.dir/WidgetFactory.cpp.o: in function `QtMetaTypePrivate::QMetaTypeFunctionHelper<PySide::PyObjectWrapper, true>::Construct(void*, void const*)':
WidgetFactory.cpp:(.text._ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE9ConstructEPvPKv[_ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE9ConstructEPvPKv]+0xa): undefined reference to `PySide::PyObjectWrapper::PyObjectWrapper(PySide::PyObjectWrapper const&)'
/usr/bin/ld: WidgetFactory.cpp:(.text._ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE9ConstructEPvPKv[_ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE9ConstructEPvPKv]+0x19): undefined reference to `PySide::PyObjectWrapper::PyObjectWrapper()'
/usr/bin/ld: CMakeFiles/FreeCADGui.dir/WidgetFactory.cpp.o: in function `QtMetaTypePrivate::QMetaTypeFunctionHelper<PySide::PyObjectWrapper, true>::Destruct(void*)':
WidgetFactory.cpp:(.text._ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE8DestructEPv[_ZN17QtMetaTypePrivate23QMetaTypeFunctionHelperIN6PySide15PyObjectWrapperELb1EE8DestructEPv]+0x1): undefined reference to
`PySide::PyObjectWrapper::~PyObjectWrapper()'
collect2: Fehler: ld gab 1 als Ende-Status zurück
make[2]: *** [src/Gui/CMakeFiles/FreeCADGui.dir/build.make:5595: lib/libFreeCADGui.so] Fehler 1
make[1]: *** [CMakeFiles/Makefile2:6081: src/Gui/CMakeFiles/FreeCADGui.dir/all] Fehler 2
make: *** [Makefile:130: all] Fehler 2
Qt version: 5.12.3
ascaron, could you please tell me what command do you use to patch?
patch -p0 after git clone?
like Kunda1 said:
I had some progress on building on Manjaro. My output of the variables after getting the properties from the patch:Kunda1 wrote: ↑Fri Jun 21, 2019 1:08 pm https://www.freecadweb.org/wiki/Source_ ... es_via_git
git apply [patch-name].patch
SHIBOKEN_INCLUDE_DIR: /usr/include/shiboken2/usr/include/python3.7m
SHIBOKEN_LIBRARY: /usr/lib/libshiboken2.cpython-37m-x86_64-linux-gnu.so.5.12.3
PYSIDE_INCLUDE_DIR: /usr/include/PySide2
PYSIDE_LIBRARY:
I am completely new to cmake, so I have no idea why those properties are not set correctly, but I will take a look later.
Thank you, ascaron.
However, it doesn't work also in my. It says it doesn't find Pyside2 and Shiboken. It finished compiling and installing, but nothing changed.
In the past building PySide always was and maybe still is a pain in the ass and also the integration into CMake is not very elegant. And I am not even sure if packages for all platforms are really provided. Thus, I prefer to avoid making it a mandatory build dependency.
So, in order to avoid to make it mandatory I have implemented an approach to set the attributes of a form using shiboken's Python interface of wrapping QWidgets: git commit cabb7339688d
Awesome, it works! Thank you very much.
