Rebuild the FEM model
S-Y.Chen
Post by S-Y.Chen » Fri May 29, 2020 5:59 am
If I have a FreeCAD FEM model, which contains the following actions
1. Import the STEP file.
2. Apply materials, BC and Loading
3. Meshing
4. solve and post-processing
If I change the geometry in the STEP file of STEP 1 with an external CAD, is there any way I can rebuild the whole model and solve (step 1 to 4) without redo all the steps above ?
Thanks for the help.
Regards
S-Y. Chen
Re: Rebuild the FEM model
Post by bernd » Fri May 29, 2020 7:05 am
3. Meshing
Regards
S-Y. Chen
With python for sure lot of things could be automated. How much afford is needed depends on the changes in your geometry. Do you change the length of edges only? Means the count of nodes, edges, faces is still the same? Or do you really change the geometry? Means you add or delete edges. Would be good if you post two examples of the changed geometry.
S-Y.Chen
Post by S-Y.Chen » Fri May 29, 2020 7:08 am
3. Meshing
Regards
S-Y. Chen
The topology of the CAD won't be changed. That means, yes, the count of nodes, edges, faces is still the same. And the ID of each CAD entity should remains the same.
S-Y.Chen
Post by S-Y.Chen » Fri May 29, 2020 7:27 am
3. Meshing
Regards
S-Y. Chen
Two STEP files attached here.
examp112_02.STEP
(15.63 KiB) Downloaded 2 times
examp112_01.STEP
(15.62 KiB) Downloaded 2 times
Post by bernd » Fri May 29, 2020 9:24 am
- open document, run analysis, show results
- run Python code
App.ActiveDocument.FEMGeom.Shape = App.ActiveDocument.getObjectsByLabel("examp112")[0].Shape
- recompute document
- remesh (if netgen mesh is used, the mesh will be chaned on document recompute)
- run analysis, show results
change_geometry_fem.FCStd
(32.18 KiB) Downloaded 4 times
S-Y.Chen
Post by S-Y.Chen » Fri May 29, 2020 10:01 am
- run Python code
Sorry, I don't quite understand the process and logics.
In the first action "- open document, run analysis, show results". Does this mean that model already imported the original STEP model ? (my step 1 tp 4?)
And, when does the change of the STEP file comes into effect ? And what does this line of code do ?
Post by bernd » Fri May 29, 2020 11:00 am
in the file is a FEM analysis which uses one ouf your geometries. The line of code does exchange the geometry of the geometrical document object from one of your geometries to the other. The attribute which holds the geometry is called Shape. Afte the geometry was exchanged the document needs recompute. The loads and fixed are adapted. Now the mesh needs do be remeshed and the analysis could be run with the exchaned geometry. Hope this helps.
At the moment the geoemtry exchange can not be done by the Gui AFAIK, but I am not sure. For reference: https://forum.freecadweb.org/viewtopic.php?f=8&t=46975
S-Y.Chen
Post by S-Y.Chen » Sun May 31, 2020 10:48 am
Script should work perfectly for me at this point. Thank you.
I did give it a try. And I am wondering how does FreeCAD decide the name of the newly imported "geometrical document object" ? Is there a way to obtain this name (through script), assuming that we need to know it in batch mode execution ?
Thank again for the help.
Post by bernd » Sun May 31, 2020 11:46 am
be aware there is a Name and a Label for each document object. Which one of both are you talking about?
S-Y.Chen
Post by S-Y.Chen » Wed Jun 03, 2020 3:28 am
Actually I just figure out there are two names (label) to be used, so I am talking about both. How do I get both name and label through script ?
And I gave it a try on my own model. I imported a STEP file examp104_01, and setup the FEM and run. And then I imported a STEP file examp104_02 again, as shown in the figure below
Then i issued the command
App.ActiveDocument.examp104_01.Shape = App.ActiveDocument.getObjectsByLabel("examp104_02")[0].Shape
But I got the following error message :
AttributeError: 'App.Document' object has no attribute 'examp104_01'
What did I do wrong here ?
Thanks again for the help !
Regard
S-Y. Chen
