Handle(Geom_Circle) circle = Handle(Geom_Circle)::DownCast(c);
const gp_Pnt& loc = circle->Axis().Location();
gp_Trsf sketchTransformation;
gp_Trsf localSketchTransformation;
Base::Placement SketchPos = profile->Placement.getValue();
Base::Matrix4D mat = SketchPos.toMatrix();
sketchTransformation.SetValues(
mat[0][0], mat[0][1], mat[0][2], mat[0][3],
mat[1][0], mat[1][1], mat[1][2], mat[1][3],
mat[2][0], mat[2][1], mat[2][2], mat[2][3]
#if OCC_VERSION_HEX < 0x060800
, 0.00001, 0.00001
#endif
); //precision was removed in OCCT CR0025194
localSketchTransformation.SetTranslation( gp_Pnt( 0, 0, 0 ),
gp_Pnt(loc.X(), loc.Y(), loc.Z()) );
testAngledDrillHole (PartDesignTests.TestHole.TestHole) ... /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/src/Mod/PartDesign/App/FeatureSketchBased.cpp:253:35: runtime error: member call on address 0x7ffff457e290 which does not point to an object of type 'BRepBuilderAPI_Copy'
0x7ffff457e290: note: object is of type 'BRepBuilderAPI_Copy'
8c 7f 00 00 e0 16 0e 4a 8c 7f 00 00 01 01 00 00 8c 7f 00 00 50 f8 9f 00 40 60 00 00 c0 1f 50 01
vptr for 'BRepBuilderAPI_Copy'
==17121==ERROR: AddressSanitizer: stack-use-after-scope on address 0x7ffff4580110 at pc 0x7f8c364648ff bp 0x7ffff457e6a0 sp 0x7ffff457e690
READ of size 8 at 0x7ffff4580110 thread T0
#0 0x7f8c364648fe in gp_XYZ::Z() const /usr/local/lib/oce-0.18/../../include/oce/gp_XYZ.lxx:71
#1 0x7f8c364af635 in gp_Pnt::Z() const /usr/local/lib/oce-0.18/../../include/oce/gp_Pnt.lxx:70
#2 0x7f8c36525f2e in PartDesign::Hole::execute() /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/src/Mod/PartDesign/App/FeatureHole.cpp:1233
#3 0x7f8c688f2fb0 in App::DocumentObject::recompute() /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/src/App/DocumentObject.cpp:89
#4 0x7f8c48e32589 in Part::Feature::recompute() /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/src/Mod/Part/App/PartFeature.cpp:83
#5 0x7f8c686ecfb9 in App::Document::_recomputeFeature(App::DocumentObject*) /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/src/App/Document.cpp:2446
#6 0x7f8c686e5cf3 in App::Document::recompute() /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/src/App/Document.cpp:2230
#7 0x7f8c68a4c6b7 in App::DocumentPy::recompute(_object*) /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/src/App/DocumentPyImp.cpp:408
#8 0x7f8c68a2de04 in App::DocumentPy::staticCallback_recompute(_object*, _object*) /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/build/src/App/DocumentPy.cpp:1718
#9 0x7f8c64d02b46 in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x118b46)
#10 0x7f8c64d0267e in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x11867e)
#11 0x7f8c64cf90c1 in PyEval_EvalCodeEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x10f0c1)
#12 0x7f8c64d7faeb (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x195aeb)
#13 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#14 0x7f8c64cfa88c in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x11088c)
#15 0x7f8c64cf90c1 in PyEval_EvalCodeEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x10f0c1)
#16 0x7f8c64d7fa1a (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x195a1a)
#17 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#18 0x7f8c64d96b8b (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1acb8b)
#19 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#20 0x7f8c64d46ff9 (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x15cff9)
#21 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#22 0x7f8c64cfe763 in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x114763)
#23 0x7f8c64cf90c1 in PyEval_EvalCodeEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x10f0c1)
#24 0x7f8c64d7faeb (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x195aeb)
#25 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#26 0x7f8c64cfa88c in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x11088c)
#27 0x7f8c64cf90c1 in PyEval_EvalCodeEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x10f0c1)
#28 0x7f8c64d7fa1a (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x195a1a)
#29 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#30 0x7f8c64d96b8b (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1acb8b)
#31 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#32 0x7f8c64d46ff9 (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x15cff9)
#33 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#34 0x7f8c64cfe763 in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x114763)
#35 0x7f8c64cf90c1 in PyEval_EvalCodeEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x10f0c1)
#36 0x7f8c64d7faeb (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x195aeb)
#37 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#38 0x7f8c64cfa88c in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x11088c)
#39 0x7f8c64cf90c1 in PyEval_EvalCodeEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x10f0c1)
#40 0x7f8c64d7fa1a (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x195a1a)
#41 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#42 0x7f8c64d96b8b (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1acb8b)
#43 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#44 0x7f8c64d46ff9 (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x15cff9)
#45 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#46 0x7f8c64cfe763 in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x114763)
#47 0x7f8c64cf90c1 in PyEval_EvalCodeEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x10f0c1)
#48 0x7f8c64d7faeb (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x195aeb)
#49 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#50 0x7f8c64cfa88c in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x11088c)
#51 0x7f8c64cf90c1 in PyEval_EvalCodeEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x10f0c1)
#52 0x7f8c64d7fa1a (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x195a1a)
#53 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#54 0x7f8c64d96b8b (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1acb8b)
#55 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#56 0x7f8c64d46ff9 (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x15cff9)
#57 0x7f8c64da9e92 in PyObject_Call (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x1bfe92)
#58 0x7f8c64cfe763 in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x114763)
#59 0x7f8c64d0267e in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x11867e)
#60 0x7f8c64d0267e in PyEval_EvalFrameEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x11867e)
#61 0x7f8c64cf90c1 in PyEval_EvalCodeEx (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x10f0c1)
#62 0x7f8c64cf96d8 in PyEval_EvalCode (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0x10f6d8)
#63 0x7f8c64cd1f15 in PyRun_StringFlags (/usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0+0xe7f15)
#64 0x7f8c65bbe36c in Base::InterpreterSingleton::runString[abi:cxx11](char const*) /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/src/Base/Interpreter.cpp:232
#65 0x7f8c68ec481d in App::Application::runApplication() /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/src/App/Application.cpp:1696
#66 0x565202d16aef in main /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/src/Main/MainGui.cpp:258
#67 0x7f8c62b7409a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
#68 0x565202d14679 in _start (/home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/build/bin/FreeCAD+0x1d679)
Address 0x7ffff4580110 is located in stack of thread T0 at offset 6416 in frame
#0 0x7f8c3651c361 in PartDesign::Hole::execute() /home/ryan/Documents/3D_modeling/FreeCAD_proj/FreeCAD/src/Mod/PartDesign/App/FeatureHole.cpp:937
This frame has 126 object(s):
[32, 33) '<unknown>'
[96, 97) '<unknown>'
[160, 161) '<unknown>'
[224, 225) 'builder'
[288, 289) '<unknown>'
[352, 353) '<unknown>'
[416, 417) '<unknown>'
[480, 488) 'invObjLoc'
[544, 552) '<unknown>'
[608, 616) 'x'
[672, 680) 'z'
[736, 744) 'x'
[800, 808) 'z'
[864, 872) 'x'
[928, 936) 'z'
[992, 1000) 'c_start'
[1056, 1064) 'c_end'
[1120, 1128) 'c'
[1184, 1192) 'circle'
[1248, 1256) '<unknown>'
[1312, 1320) '<unknown>'
[1376, 1400) 'profileshape'
[1440, 1464) '<unknown>'
[1504, 1528) 'base'
[1568, 1592) 'SketchVector'
[1632, 1656) 'zDir'
[1696, 1720) 'xDir'
[1760, 1784) '<unknown>'
[1824, 1848) '<unknown>'
[1888, 1912) '<unknown>'
[1952, 1976) 'firstPoint'
[2016, 2040) 'lastPoint'
[2080, 2104) 'newPoint'
[2144, 2168) '<unknown>'
[2208, 2232) '<unknown>'
[2272, 2296) '<unknown>'
[2336, 2360) '<unknown>'
[2400, 2424) '<unknown>'
[2464, 2488) '<unknown>'
[2528, 2552) '<unknown>'
[2592, 2616) '<unknown>'
[2656, 2680) '<unknown>'
[2720, 2744) 'newPoint'
[2784, 2808) '<unknown>'
[2848, 2872) '<unknown>'
[2912, 2936) '<unknown>'
[2976, 3000) '<unknown>'
[3040, 3064) '<unknown>'
[3104, 3128) '<unknown>'
[3168, 3192) '<unknown>'
[3232, 3256) '<unknown>'
[3296, 3320) '<unknown>'
[3360, 3384) '<unknown>'
[3424, 3448) '<unknown>'
[3488, 3512) '<unknown>'
[3552, 3576) '<unknown>'
[3616, 3640) 'newPoint'
[3680, 3704) '<unknown>'
[3744, 3768) 'newPoint'
[3808, 3832) '<unknown>'
[3872, 3896) '<unknown>'
[3936, 3960) '<unknown>'
[4000, 4024) '<unknown>'
[4064, 4088) '<unknown>'
[4128, 4152) 'newPoint'
[4192, 4216) '<unknown>'
[4256, 4280) '<unknown>'
[4320, 4344) '<unknown>'
[4384, 4408) '<unknown>'
[4448, 4472) '<unknown>'
[4512, 4536) '<unknown>'
[4576, 4600) '<unknown>'
[4640, 4664) '<unknown>'
[4704, 4728) '<unknown>'
[4768, 4792) '<unknown>'
[4832, 4856) '<unknown>'
[4896, 4920) 'wire'
[4960, 4984) 'face'
[5024, 5048) '<unknown>'
[5088, 5112) 'protoHole'
[5152, 5176) 'holes'
[5216, 5240) 'edge'
[5280, 5304) '<unknown>'
[5344, 5368) '<unknown>'
[5408, 5432) 'copy'
[5472, 5496) 'result'
[5536, 5560) '<unknown>'
[5600, 5624) '<unknown>'
[5664, 5688) '<unknown>'
[5728, 5752) '<unknown>'
[5792, 5816) '<unknown>'
[5856, 5880) '<unknown>'
[5920, 5944) '<unknown>'
[5984, 6008) '<unknown>'
[6048, 6072) '<unknown>'
[6112, 6136) '<unknown>'
[6176, 6200) '<unknown>'
[6240, 6272) 'edgeMap'
[6304, 6352) '<unknown>'
[6400, 6448) '<unknown>' <== Memory access at offset 6416 is inside this variable
[6496, 6648) '<unknown>'
[6688, 6888) '<unknown>'
[6944, 7144) '<unknown>'
[7200, 7400) '<unknown>'
[7456, 7656) '<unknown>'
[7712, 7912) '<unknown>'
[7968, 8168) '<unknown>'
[8224, 8424) '<unknown>'
[8480, 8680) '<unknown>'
[8736, 8936) '<unknown>'
[8992, 9192) '<unknown>'
[9248, 9448) '<unknown>'
[9504, 9728) 'mkCut'
[9760, 10064) 'mkWire'
[10112, 10424) 'RevolMaker'
[10464, 10496) 'method'
[10528, 10560) 'holeCutType'
[10592, 10624) 'drillPoint'
[10656, 10688) '<unknown>'
[10720, 10752) '<unknown>'
[10784, 10816) '<unknown>'
[10848, 10936) 'SketchPos'
[10976, 11088) 'sketchTransformation'
[11136, 11248) 'localSketchTransformation'
[11296, 11424) 'mat'
[11456, 11736) 'transformer'
HINT: this may be a false positive if your program uses some custom stack unwind mechanism or swapcontext
(longjmp and C++ exceptions *are* supported)
SUMMARY: AddressSanitizer: stack-use-after-scope /usr/local/lib/oce-0.18/../../include/oce/gp_XYZ.lxx:71 in gp_XYZ::Z() const
Shadow bytes around the buggy address:
0x10007e8a7fd0: f2 f2 f2 f2 00 00 00 f2 f2 f2 f2 f2 00 00 00 f2
0x10007e8a7fe0: f2 f2 f2 f2 00 00 00 f2 f2 f2 f2 f2 00 00 00 f2
0x10007e8a7ff0: f2 f2 f2 f2 00 00 00 f2 f2 f2 f2 f2 00 00 00 f2
0x10007e8a8000: f2 f2 f2 f2 00 00 00 f2 f2 f2 f2 f2 00 00 00 00
0x10007e8a8010: f2 f2 f2 f2 f8 f8 f8 f8 f8 f8 f2 f2 f2 f2 f2 f2
=>0x10007e8a8020: f8 f8[f8]f8 f8 f8 f2 f2 f2 f2 f2 f2 f8 f8 f8 f8
0x10007e8a8030: f8 f8 f8 f8 f8 f8 f8 f8 f8 f8 f8 f8 f8 f8 f8 f2
0x10007e8a8040: f2 f2 f2 f2 00 00 00 00 00 00 00 00 00 00 00 00
0x10007e8a8050: 00 00 00 00 00 00 00 00 00 00 00 00 00 f2 f2 f2
0x10007e8a8060: f2 f2 f2 f2 00 00 00 00 00 00 00 00 00 00 00 00
0x10007e8a8070: 00 00 00 00 00 00 00 00 00 00 00 00 00 f2 f2 f2
Shadow byte legend (one shadow byte represents 8 application bytes):
Addressable: 00
Partially addressable: 01 02 03 04 05 06 07
Heap left redzone: fa
Freed heap region: fd
Stack left redzone: f1
Stack mid redzone: f2
Stack right redzone: f3
Stack after return: f5
Stack use after scope: f8
Global redzone: f9
Global init order: f6
Poisoned by user: f7
Container overflow: fc
Array cookie: ac
Intra object redzone: bb
ASan internal: fe
Left alloca redzone: ca
Right alloca redzone: cb
==17121==ABORTING
If you want to check the line numbers in the above error, please see commit 92d138d1b564fedc64913bf27297adcf74f38bfe at https://github.com/rlee287/FreeCAD/tree ... cf74f38bfe in my own fork of the FreeCAD repo (branched from the 0.17 release). I changed the reference to a value in commit c1541309b67f255685daa1b096145192e4e804b1 in my fork, at https://github.com/rlee287/FreeCAD/comm ... 92e4e804b1.
