Flexible assemblies. How manage them ?
I submitted several months ago the problem of flexible assembly, because it's now a significant hurdle slowing my projects. So I imagined a factious machine to exhibit what's going on, in a synthetic fashion (show all the cases), and kept as simple as possible. This issue concerns each applicant workbench as the future assembly module, thus this detached thread.
The key point is of course an engineer wants to shape his project, in particular how it will be split, with functional subdivision in mind. And not how the CAD would be pleased, because it eases its process of constraining.
It's just a first draft. I gave you the tree structure the user would probably wants. For the sake of clarity, pure assemblies are all prefixed using this pattern : A_*.FCStd.
I roughly placed the parts/assemblies in the 3d view, the required constraints are obvious.
An under-constrained sub-assembly :
Gear-motor -> DOF rot=1
An under-constrained sub-assembly inserted several times at same level, but using different configurations :
Cylinder -> DOF rot=1, transl=1
More to come...
So as you can see, even with this miserable examples, you can't fully apply constraints. See all of this as just a starting point for a global thinking about the subject.
(I have a tarball on my pc of this test assembly).
Re: Flexible assemblies. How manage them ?
I am not sure I understood your problem, sorry if this freedback is beside the point, then.
My projects all have that structure and they work great. But I note that my tree looks different from yours. I use pure assembly files (I guess that is what you A-Motor is, I name them "asm_Motor" - just cosmetics), one at each level. Each assembly file includes other (lower) assembly files and uses constraints to assembly them. Each mechanical module gets a folder on disk. Typically only the lowest levels contains pure part files. I also use a lot of STEP files for library parts (e.g. DIN/ISO parts) - gladly realthunder added the import STEP function, so you can directly include that file from the Assembly3 WB.
So the difference I see is, that when I have my "asm_Machine-FCSTD" open, I would see this
Under "parts" all leafs are links, the "asm_xxx" are links to assemblies, the others are links to direct files. The constraints and elements define the assembly and the kinematics of the structure.
In your tree I do not see that. it looks to me like pure links with no constraints. Maybe thats fine, I have never used that. I only can say that my structure worked quite good so far.
asm_Machine-FCSTD
Assembly
constraints
elements
parts
asm_cylinder
frame
gear
lowerArm
asm_Motor
rotatingBase
upperArm
Some precision :
The tree shows how the files and directories are stored on my disk.
At the moment I use a2+
Yes, A_Something.FCStd are pure containers, so with constraints stored into them, but *only* imported parts. The prefix is just a personal naming convention to instantly recognize them as assemblies.
A practical example : I can't insert A_Cylinder.FCstd two times into A_Machine.FCStd, with two different states : one with rod retracted, the other with rod expanded, because they are considered *monolithic* inside A_Machine.FCStd, even if I leave a free translation into A_Cylinder.FCStd.
Sorry, it's sometime hard to explain clearly what's going on !
That was my mistake. Since you linked your post in the Assembly3 thread I assumed that you were using assembly3 workbench with the 0.19 pre-version. So what I wrote would not apply to A2+ automatically.
I was using A2+ some time ago to do so something similar: having a low poly version of a part and a detailed version, which I could swap. Somehow I did not get that done. I found that I could do it with Assembly4. This is also based on the Link-core extensions that Assembly3 uses but based on defining local coordinate systems (LCS) for each part. You can attach serveral parts to another's parts LCS and use <space> to hide/disable the unwanted one. In your case its not different level of detail, its just different states. With Assembly3 that can be done as well. If your have not worked with Assemby3 before, I think Assembly4 might be more suitable for your case.
I understand the idea you suggested.
The problem is no asm3 plugin are provided. My real projects are really huge, no way I will switch without careful planning. I really hope an official assembly module will be chosen, even if it lacks significant features.
here is an example I had built in Asm3 to try to kinematically animate a mechanism :
Cinematic animation:
http://help-freecad-jpg87.fr/02assembla ... sm3WB.html
Each object is located in an external file and represented in the assembly by a link.
Each object is here very simplified but could itself be a sub-assembly made up of several parts.
You can see that the arm and bucket cylinders come from the same PartDesign part and are two independent instances in operation.
According to my point of view, a component purchased commercially (cylinder, motor, ...) must be prepared beforehand in several sub-assemblies.
Maybe some CAD software allows you to make "flexible" assemblies, but I don't find this function essential.
In any case, when we recover the 3D files of a commercial component (often in step format), they are not yet assembled within the meaning of the assembly constraints.
Example of a hydraulic (or pneumatic) cylinder:
1- the cylinder body (with its articulation, joints, guide, ...);
2- the piston of the cylinder (with its articulation, the seals, ...).
Example of an electric motor:
1- the motor body (with its frame, the stator, ...);
2- the rotating part of the motor (rotor, ...).
My website : http://help-freecad-jpg87.fr updated 2023/11/06
May be I should try to explain what the interface could show, to my point of view.
It's a classic expandable/collapsible tree (the same sort of widget sometime used for traveling through a directory/file structure).
Each assembly node (here named A_*) can be collapsed.
The location on the disk of a part or an assembly doesn't matter, a pointer is used to target where it's located.
I really think it's the clearest way to represent an assembly.
Now, returning to the initial problem.
Opening A_Cylinder *alone*, the user would see the rod with DOF:rot=1, trans=1.
Then opening A_Machine, to now fully constrain the two cylinders, A_machine must store the additional constraints (to fully set the two rods) *inside* itself. THAT'S THE POINT !
I think it's clear.
@jpg87
1) The problem is the structure I see in your example is flat, and I don't want that.
2) I know that components purchased off-the-shelf are problematic when they are assemblies (assuming downloaded as *.step). Step file doesn't manage this sort of flexiblity, as far as I know.
I think it's clear.
@jpg87
yes, I remember, it was about a cardan joint, and I gave you a solution to your problem.
This is a typical example of a solution looking for a problem. Technically, a flexible assembly is actually a badly defined combination of 2 (or more) stiff assemblies. For example, in your example of the motor composed of a stator and a rotor, the stator and the rotor are both fixes to their respective sub-assemblies, and not a flexible assembly of 2 components.
What I would do is to define your motor in a separate file, with all components in separate parts, inside the same file. This way, you can design your motor in a coherent way, even parametrically such that the rotor and stator share the same dimensions. Then, with Asm4, define the locations (LCS) of your moving parts in a master sketch, probably with the help of some variables. Then, insert both parts (Stator and Rotor) separately and attached to their respective locations, as defined previously. This way, your motor (composed of several parts) can be held in a single file, designed parametrically and coherently, and yet still be inserted as separate components with moving parts attached to where they belong.
This, actually, is unique to FreeCAD, and much better than what other 3D CAD systems can propose.
So we see appearing here different conceptions of how a tree should be structured.
I perfectly understand the suggested method but I just don't like it. I like to split a machine tree using a logic as close as possible to what the physical equivalent components would be. I'm *prioritizing* assembly process, rather than kinematic logic (although of course I strive to combine both, then if I can it's a clear bonus). This logic is debatable, but I am sure the result I'm getting is not a hodgepodge of incoherence.
Thinking afterwards about the term, may be there is a better word than "flexible" (I reused the one found in the commercial CAD literature), that is simply : "partially constrained". Well, because it's just what exactly happens...
The way I represented the motor was a simplification, the A_stator included in my mind all the fixed parts (casing included). So the A_rotor is indeed underscontrained relatively to its parent A_Motor (dof rot=1). I meant flexible in that way.
Below a better representation closer to reality : Anyway... I'm not trying to convince anyone my method is better than any other. Ideally, a CAD should bestow each user full latitude of how his assembly could be structured (excepted of course an absurdity like a circular reference).
I'm cautious because without a serious reading of the code it's hard to say, but I can't figure at this stage anything preventing the usage of underconstrained sub-assemblies. After opening an assembly, once the recursive loading is done, position of a part/assembly in the tree doesn't matter. I don't see here a fundamental hurdle for an algorithm.
- Gregory son of Carl
How about using Groups to replicate the hierarchy of the sub-assemblies? That would let you follow Zolko's method without sacrificing the tree structure.
