Compile_on_Linux
[Solved] CompileOnUnix wiki page
Re: CompileOnUnix wiki page
Still can't move the dang page
- kkremitzki
So it seems we need Yorik to unlock the page then?
Do you know how this can be solved? There are some pages that are locked.yorik wrote: ping
We need to solve this issue.
Current page: Compile_on_Linux/Unix
It does not work with the forum wiki tags: [wiki]Compile_on_Linux/Unix[/wiki]
The page should be named: Compile_on_Linux
It does work with the forum tags: Compile_on_Linux
The old page that remains locked: CompileOnUnix
Like I said on a related thread, this won't be an issue on the new https://wiki.freecadweb.org (heads up: this is a staging snapshot of our current wiki for testing purposes)
So we either suffer a few more days without the link working and testing if everything works on the new wiki..or we just bite the bullet: synch the new wiki and make it live.
I personally vote for the former option.
Ok, I'm planning to work on this today.
What i need to check first is what are the differences between
CompileOnUnix
and
It looks like I should move Compile_on_Linux/Unix -> Compile on Linux
I'll need to make sure the translation files are moved correctly also.
Wish me luck
CompileOnUnix
and
Wish me luck
Bad news: AFAICT, it's not possible to add redirects on subpages and therefore we have no capability to redirect Compile on Unix/Linux to Compile on Linux (including translations) case in point: https://wiki.freecadweb.org/Compile_on_Linux/Unix cancel clear. this works!
Good news: I've moved Compile on Unix/Linux to Compile on Linux (and all its translation pages) and created redirects to all
what should we do about CompileOnUnix ? redirect it to Compile on Linux ?
There are a lot of translation pages of it. It would be a shame to neglect. Any suggestions?
I can suggest that you combine these two documents.
From the document compile on unix, make a chapter of the former.
I expect that this suggestion will not be easy to do either.
Twórca polskiej wersji Wiki dla FreeCAD, współwórca polskiej wersji GUI.
"Cierpliwym być musisz, by wiedzę zgłębiać tajemną, gdyż ciemna strona mocy niszczącą i silną jest".
