The minor errors I encountered during the translation
kaktus
Post by kaktus » Sun Feb 09, 2020 10:04 am
Hi.
:mrgreen:
I have decided to post here small errors that I encounter while translating the documents and that I am not able to correct by myself. :roll:
Maybe someone can solve them.
https://www.freecadweb.org/wiki/Std_Edit
wierny padawan mistrza arturromarr
Twórca polskiej wersji Wiki dla FreeCAD.
mario52
Re: The minor errors I encountered during the translation
Post by mario52 » Sun Feb 09, 2020 1:20 pm
hi friend
Std_Alignment.svg not exist change the .svg in .png or delette it
for result "|IconL=" and not icon dispayed
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
kaktus
Post by kaktus » Sun Feb 09, 2020 4:15 pm
:D
Thank you for your suggestions. I also corrected the original document.
vocx
Post by vocx » Mon Feb 10, 2020 2:13 am
Instead of using the PNG version, you should upload the corresponding SVG image, and use that instead.
We should prefer the SVG image in all cases because it should be smaller in disk drive space, and can be scaled to any size that we need.
kaktus
Post by kaktus » Mon Feb 10, 2020 2:58 pm
Haaaa
:D
I found the source of the icons.
:mrgreen:
Post by Kunda1 » Mon Feb 10, 2020 10:21 pm
We need a way to find out if the compatible SVG has already been uploaded. There is no need to have duplicate SVGs named differently. I opened a thread in the UI/UX subforum asking for assistance with this issue:
https://forum.freecadweb.org/viewtopic.php?f=34&t=43189
kaktus
Post by kaktus » Sat Feb 15, 2020 11:04 am
https://www.freecadweb.org/wiki/Preferences_Editor/pl
Unable to translate the message: {{VeryImportantMessage...}}
The section was probably not made available for translation. :roll:
mario52
Post by mario52 » Sat Feb 15, 2020 1:51 pm
hi
no problem you can correct my "Google translation"
mario
kaktus
Post by kaktus » Sat Feb 15, 2020 2:57 pm
:mrgreen:
thanks to
the next document with a similar problem:
https://www.freecadweb.org/wiki/Part_Booleans/pl
The amount of changes generated by the new Bot Wiki is overwhelming. :shock:
I think most of them could also be referenced in all language versions.
Of course these changes are very necessary. However, they require too much work and effort for translators to maintain documents. :roll:
kaktus
Post by kaktus » Sat Feb 15, 2020 3:34 pm
