1. Run macro
2. press 'a' key
3. navigational pop-up appears
4. choose a sphere that represents a certain workbench
Result: workbench opens
Here is a screencast of it in action:
Here is the macro:
from __future__ import division
import FreeCADGui as Gui
import numpy as np
class PieButton(QtGui.QGraphicsEllipseItem):
def __init__(self, pos=[0, 0], angle_range=(0, 1), size=[50, 50], view=None, parent=None):
super(PieButton, self).__init__(None, scene=parent)
self.view = view
self.angle_range = angle_range
self.setRect(pos[0] - size[0] / 2, pos[1] - size[1] / 2, size[0], size[1])
self.setBrush(QtGui.QBrush(QtCore.Qt.red))
self.setAcceptHoverEvents(True)
self.command = None
self.hoover = False
def setHoover(self, value):
if not self.hoover == value:
self.hoover = value
if value:
self.setBrush(QtGui.QBrush(QtCore.Qt.blue))
self.view.setText(self.command[0])
else:
class PieView(QtGui.QGraphicsView):
def __init__(self, key, commands, parent=None):
super(PieView, self).__init__(parent)
self.key = key
self.setWindowFlags(QtCore.Qt.Widget | QtCore.Qt.FramelessWindowHint)
self.setAttribute(QtCore.Qt.WA_TranslucentBackground)
self.setStyleSheet("QGraphicsView {border-style: none; background: transparent;}" )
self.setHorizontalScrollBarPolicy(QtCore.Qt.ScrollBarAlwaysOff)
self.setVerticalScrollBarPolicy(QtCore.Qt.ScrollBarAlwaysOff)
self.scene = QtGui.QGraphicsScene(self)
self.scene.setSceneRect(-200, -200, 400, 400)
self.setScene(self.scene)
self.center = [0, 0]
self.buttons = []
self.label = QtGui.QGraphicsSimpleTextItem("")
self.scene.addItem(self.label)
self.add_commands(commands)
def setText(self, text):
self.label.setText(text)
self.label.update()
self.label.setPos(-self.label.sceneBoundingRect().width() / 2, 0)
def add_commands(self, commands):
num = len(commands)
r = 100
a = 70
pie_phi = np.linspace(0, np.pi * 2, num + 1)
phi = [(p + pie_phi[i + 1]) / 2 for i, p in enumerate(pie_phi[:-1])]
for i, command in enumerate(commands):
button = PieButton(
[r * np.cos(phi[i]), r * np.sin(phi[i])],
[pie_phi[i], pie_phi[i + 1]],
[a, a], self, self.scene)
button.command = command
self.scene.addItem(button)
self.buttons.append(button)
def mouseMoveEvent(self, event):
r2, angle = self.polarCoordinates
hoover = False
for item in self.buttons:
if (item.angle_range[0] < angle and
angle < item.angle_range[1] and
r2 > 1000):
item.setHoover(True)
hoover = True
else:
item.setHoover(False)
if not hoover:
self.setText("")
@property
def polarCoordinates(self):
pos = QtGui.QCursor.pos() - self.center
r2 = pos.x() ** 2 + pos.y() ** 2
angle = np.arctan2(pos.y(), pos.x())
return r2, angle + (angle < 0) * 2 * np.pi
def showAtMouse(self, event):
if event["Key"] == self.key:
self.show()
self.center = QtGui.QCursor.pos()
self.move(self.center.x()-(self.width()/2), self.center.y()-(self.height()/2))
def keyReleaseEvent(self, event):
super(PieView, self).keyReleaseEvent(event)
if event.key() == QtGui.QKeySequence(self.key):
if not event.isAutoRepeat():
for item in self.scene.items():
if hasattr(item, "hoover"):
if item.hoover:
item.command[1]()
self.hide()
if __name__ == "__main__":
def part_design(): Gui.activateWorkbench("PartDesignWorkbench")
def part(): Gui.activateWorkbench("PartWorkbench")
def draft(): Gui.activateWorkbench("DraftWorkbench")
def arch(): Gui.activateWorkbench("ArchWorkbench")
def fem(): Gui.activateWorkbench("FemWorkbench")
def sketch(): Gui.activateWorkbench("SketcherWorkbench")
def draw(): Gui.activateWorkbench("DrawingWorkbench")
def mesh(): Gui.activateWorkbench("MeshWorkbench")
command_list = [
["PartDesign", part_design],
["Part", part],
["Draft", draft],
["Arch", arch],
["Fem", fem],
["sketch", sketch],
["draw", draw],
["mesh", mesh]]
a = PieView("a", command_list)
view = Gui.ActiveDocument.ActiveView
view.addEventCallback("SoKeyboardEvent", a.showAtMouse)
1) Display all available workbenches as spheres with their respective logos
2) When hovering over a specific workbench sphere that it will immediately vanish all the other spheres and open the commands of that said workbench in separate discrete spheres to choose from.
Result: time-saving travel time going back and forth from the toolbars to the canvas
Any pyside-nistas available to help ?
