To start FreeCAD in console mode (this will drop you in to a python shell)
Linux/MacOS
freecadcmd
or
freecad -c
freecadcmd.exe
or
freecad.exe -c
The AppImage may not find certain modules, so it's possible to use the -M <path-to-system-python-modules> flag which directs it to use the system modules.
# swap out for the correct path on your system
./FreeCAD.AppImage -c -M /usr/lib/python3.7/site-packages
Unpacked Appimage (link)
FreeCAD.AppImage --appimage-extract
cd squashfs-root/
./AppRun -c -M /usr/lib/python3.7/site-packages
What version of python is the shell running?
import sys
print(sys.version)
import readline
import FreeCAD
import readline, FreeCAD
print(FreeCAD.Version())
import pprint
pprint.pprint(FreeCAD.Version())
FreeCAD.getUserAppDataDir()
appdata = FreeCAD.getUserAppDataDir()
print(appdata)
dir(FreeCAD)
pprint.pprint(dir(FreeCAD))
help(FreeCAD.ConfigDump)
print(FreeCAD.ConfigDump())
# aaaand lets use pprint again
pprint.pprint(FreeCAD.ConfigDump())
pprint.pprint(dir(FreeCAD.ConfigDump))
import fancycompleter
fancycompleter.interact(persist_history=True)
FreeCAD.<TAB>
We can import pretty much any workbench (Note: not all of them or their total functionalities are exposed to python)
import Arch
import Draft
import Fem
import Part
import PartDesign
import Path
import Sketcher
import Spreadsheet
import TechDraw
help(FreeCAD)
- Print the contents of user.cfg (openBrain's script)
- How to print the About FreeCAD version info to console? <-- anyone know how to do this?
- How to print all the python api functions for each workbench? help(FreeCAD)
- How to import external workbenches and some examples
- more...
