I am creating an array of parts ( I didn't found any way to do it using makeArray ).
So I have a loop where I copy an object move it and I need to fuse it with the "total" object.
Is there a way to start with an empty Part where all other parts may be fused into ?
fusing more objects into one
Re: fusing more objects into one
Hello, and welcome to the forum.
What is a part ? What is a object ? Can you give examples.
The Draft WB included an array object. That inherits the fuse function from draftlink. See source code ..
