TheMarkster wrote this in a post and it got me fired up to generate a macro:
https://forum.freecadweb.org/viewtopic. ... 88#p444030
See the last post.
Assigning sketches to standard planes, macro
Re: Assigning sketches to standard planes, macro
Could you add possibility too remap to selected objects CS? Like add a datum plane and remap several linked sketches to it for easy common manipulation?
See last post.
Old info, removed
I plan to add recompute to the macro, I have had some FreeCAD crashes, this thing is a bit dangerous without a recompute I think. You can also imagine as I do that mapping a sketch to new place could have some serious issues if not done in a correct way and finished completely.
If anyone has thoughts about features that could make this more useful as a test bed for anti-TNP modeling. Is there some sort of next step?
Some thoughts I had:
1) I could add an auto assign to sketch button that would automatically assign a sketch to a plane when exiting Sketcher.
2)A thought, could everything just be assigned to the XY_Plane. If I create a model and pad, then pocket a few features the model doesn't care if I map everything to the XY_plane, the Pad/pocket holds the correct offsets, granted they can be very complex in the properties, but not in the Pad/Pocket task combo view windows
3) When the remapping occurs could the map-to face location be saved and compared later for changes.
Thanks
Thanks
Removed all, old info
Removed all
Could you please give a workflow how to use the script.
I did the following:
- create a sketch and a datum plane
- start the script
- select the sketch
- click the XY-Plane button
- select the plane
- click the upper Map to support button
Returned are the messages:
- start the script
- select the sketch
- select the plane
1372.47 <App> Document.cpp(3151): The graph must be a DAG.
1372.52 <App> Document.cpp(3504): Unbenannt#Sketch still touched after recompute
This macro keeps the location of your sketch but assigns the Support to a standard plane.
Step #1,
You select the reference in the tree and click the button, you will see the button text populate. Let's say it states "XY_plane001". You can use Origin planes/Datum Planes/LCS as a support target. The default is XY_plane. Be sure to use the numbered plane/datum/LCS that go with the targeted sketch.
Step #2,
Select a sketch and click Map to support, your now finished with one mappping. If you go look at the sketch support you will see XY_Plane001 as the support field.
If you are mapping to the same plane again you don't need to do step #1 again, just repeat step #2.
Step #1,
Step #2,
- Map_to_standard_plane2.FCMacro
- (7.55 KiB) Downloaded 9 times
- map_to.png (51.17 KiB) Viewed 315 times
