I have a big understandig problem. This macro:
import FreeCAD
from PySide import QtGui, QtCore
import TechDraw
class Thread(QtGui.QWidget):
def __init__(self):
super(Thread, self).__init__()
self.initUI()
def initUI(self):
row_broad = 175
self.label_Parameter = QtGui.QLabel("Parameters", self)
self.label_Parameter.setFixedWidth(row_broad)
self.label_thread_diameter = QtGui.QLabel("Thread Diameter", self)
self.line_edit_thread_diamter = QtGui.QLineEdit(self)
self.line_edit_thread_diamter.setFixedWidth(row_broad)
self.label_mm_1 = QtGui.QLabel("mm", self)
self.label_thread_lenght = QtGui.QLabel("Thread Lenght", self)
self.line_edit_thread_lenght = QtGui.QLineEdit(self)
self.line_edit_thread_lenght.setFixedWidth(row_broad)
self.label_mm_2 = QtGui.QLabel("mm", self)
self.label_hard_line_thickness = QtGui.QLabel("Hard Line Thickness", self)
self.line_edit_hard_line_thickness = QtGui.QLineEdit(self)
self.line_edit_hard_line_thickness.setFixedWidth(row_broad)
self.line_edit_hard_line_thickness.setText("0.7")
self.label_mm_3 = QtGui.QLabel("mm", self)
self.label_smooth_line_thickness = QtGui.QLabel("Smooth Line Thickness", self)
self.line_edit_smooth_line_thickness = QtGui.QLineEdit(self)
self.line_edit_smooth_line_thickness.setFixedWidth(row_broad)
self.line_edit_smooth_line_thickness.setText("0.35")
self.label_mm_4 = QtGui.QLabel("mm", self)
self.label_view = QtGui.QLabel("View", self)
self.line_edit_View = QtGui.QLineEdit(self)
self.line_edit_View.setFixedWidth(row_broad)
self.label_points = QtGui.QLabel("Create Construction Points", self)
self.checkbox_points = QtGui.QCheckBox(self)
self.checkbox_points.setCheckState(QtCore.Qt.Checked)
self.label_space_1 = QtGui.QLabel("", self)
self.label_plane_view = QtGui.QLabel("Plane View", self)
self.label_start_angle = QtGui.QLabel("Start Angle", self)
self.line_edit_start_angle = QtGui.QLineEdit(self)
self.line_edit_start_angle.setFixedWidth(row_broad)
self.line_edit_start_angle.setText("75")
self.label_degree_1 = QtGui.QLabel("°", self)
self.label_end_angle = QtGui.QLabel("End Angle", self)
self.line_edit_end_angle = QtGui.QLineEdit(self)
self.line_edit_end_angle.setFixedWidth(row_broad)
self.line_edit_end_angle.setText("345")
self.label_degree_2 = QtGui.QLabel("°", self)
self.label_center_arc = QtGui.QLabel("Center Arc", self)
self.line_edit_center_arc = QtGui.QLineEdit(self)
self.line_edit_center_arc.setFixedWidth(row_broad)
self.button_inner_thread_plain_view = QtGui.QPushButton("Inner Thread Plain View", self)
self.button_outer_thread_plain_view = QtGui.QPushButton("Outer Thread Plain View", self)
self.label_space_2 = QtGui.QLabel("", self)
self.label_side_section_view = QtGui.QLabel("Plane/Section View", self)
self.label_start_point = QtGui.QLabel("Start Point", self)
self.line_edit_start_point = QtGui.QLineEdit(self)
self.line_edit_start_point.setFixedWidth(row_broad)
self.label_direction_point = QtGui.QLabel("Direction Point", self)
self.line_edit_direction_point = QtGui.QLineEdit(self)
self.line_edit_direction_point.setFixedWidth(row_broad)
self.button_inner_thread_side_view = QtGui.QPushButton("Inner Thread Side View", self)
self.button_inner_thread_section_view = QtGui.QPushButton("Inner Thread Section View", self)
self.button_outer_thread_side_view = QtGui.QPushButton("Outer Thread Side View", self)
self.button_outer_thread_side_view.setFixedWidth(row_broad)
self.button_outer_thread_section_view = QtGui.QPushButton("Outer Thread Section View", self)
self.label_debug = QtGui.QLabel("x", self)
layout = QtGui.QGridLayout()
self.setWindowTitle("Threads")
i = 0
layout.addWidget(self.label_Parameter, i, 0)
i = i + 1
layout.addWidget(self.label_thread_diameter, i, 0)
layout.addWidget(self.line_edit_thread_diamter, i, 1)
layout.addWidget(self.label_mm_1, i, 2)
i = i + 1
layout.addWidget(self.label_thread_lenght, i, 0)
layout.addWidget(self.line_edit_thread_lenght, i, 1)
layout.addWidget(self.label_mm_2, i, 2)
i = i + 1
layout.addWidget(self.label_hard_line_thickness, i, 0)
layout.addWidget(self.line_edit_hard_line_thickness, i, 1)
layout.addWidget(self.label_mm_3, i, 2)
i = i + 1
layout.addWidget(self.label_smooth_line_thickness, i, 0)
layout.addWidget(self.line_edit_smooth_line_thickness, i, 1)
layout.addWidget(self.label_mm_4, i, 2)
i = i + 1
layout.addWidget(self.label_view, i, 0)
layout.addWidget(self.line_edit_View, i, 1)
i = i + 1
layout.addWidget(self.label_points, i, 0)
layout.addWidget(self.checkbox_points, i, 1)
i = i + 1
layout.addWidget(self.label_space_1, i, 0)
i = i + 1
layout.addWidget(self.label_plane_view, i, 0)
i = i + 1
layout.addWidget(self.label_start_angle, i, 0)
layout.addWidget(self.line_edit_start_angle, i, 1)
layout.addWidget(self.label_degree_1, i, 2)
i = i + 1
layout.addWidget(self.label_end_angle, i, 0)
layout.addWidget(self.line_edit_end_angle, i, 1)
layout.addWidget(self.label_degree_2, i, 2)
i = i + 1
layout.addWidget(self.label_center_arc, i, 0)
layout.addWidget(self.line_edit_center_arc, i, 1)
i = i + 1
layout.addWidget(self.button_inner_thread_plain_view, i, 0)
layout.addWidget(self.button_outer_thread_plain_view, i, 1)
i = i + 1
layout.addWidget(self.label_space_2, i, 0)
i = i + 1
layout.addWidget(self.label_side_section_view, i, 0)
i = i + 1
layout.addWidget(self.label_start_point, i, 0)
layout.addWidget(self.line_edit_start_point, i, 1)
i = i + 1
layout.addWidget(self.label_direction_point, i, 0)
layout.addWidget(self.line_edit_direction_point, i, 1)
i = i + 1
layout.addWidget(self.button_inner_thread_side_view, i, 0)
layout.addWidget(self.button_inner_thread_section_view, i, 1)
i = i + 1
layout.addWidget(self.button_outer_thread_side_view, i, 0)
layout.addWidget(self.button_outer_thread_section_view, i, 1)
i = i + 1
layout.addWidget(self.label_debug, i, 0)
self.setLayout(layout)
self.show()
print("test")
self.button_outer_thread_section_view.clicked.connect(self.xxxx)
print("test")
# def xxxx(self):
# print("test")
Thread()
File "/home/user/.FreeCAD/Macro/Thread.FCMacro", line 186, in <module>
Thread()
File "/home/user/.FreeCAD/Macro/Thread.FCMacro", line 9, in __init__
self.initUI()
File "/home/user/.FreeCAD/Macro/Thread.FCMacro", line 181, in initUI
<class 'AttributeError'>: 'Thread' object has no attribute 'xxxx'
But when i uncomment the line 184 - 185, the script does not work (or it does work but do not get a GUI, because i do not get an error message). Has someone an idea why. Work with this https://wiki.freecadweb.org/PySide_Inte ... e_Examples documentation.
Note: i am not a python guy, sorry when the question is dumb. Also note: in the docu there is used PySide with Python 2, i use Python 3 with Pyside 2, but is on a small GUI like that a difference? I have not find a PySide 2 docu.
FreeCAD Info:
OS: Debian GNU/Linux bullseye/sid (X-Cinnamon/lightdm-xsession)
Version: 0.19.23110 (Git)
Build type: ReleaseWithDebInfo
Hash: 711b4440f25e2fb24d20d72fe2b8af415d5959b1
Python version: 3.9.0+
Qt version: 5.15.1
Coin version: 4.0.0
OCC version: 7.5.0
Sorry for bad english
Greetings
user1234
