BIM Addon version number?
Since the BIM Addon can be updated independently, does it have its own version number?
Reason: changed title for more clarity: s/nr/number/
Re: BIM Addon version nr?
@Yorik hasn't given it an version yet, AFAIK
I guess the version number is just the commit hash taken from the addon's own repository.
All addons are hosted in a separate repository FreeCAD-addons, which just pulls one commit (the latest?) from the individual repositories, in this case yorikvanhavre/BIM_Workbench. Since Yorik only has a single master, and no releases or tags, I guess it could be thought of as a rolling release.
Thanks for your answers.
I can find the latest commit hash for the version on GitHub, but how would you find this for the version you have installed?
https://github.com/FreeCAD/FreeCAD/blob ... rs.py#L527
if os.path.exists(clonedir):
self.info_label.emit("Updating module...")
if git:
if not os.path.exists(clonedir + os.sep + '.git'):
# Repair addon installed with raw download
bare_repo = git.Repo.clone_from(self.repos[idx][1], clonedir + os.sep + '.git', bare=True)
try:
with bare_repo.config_writer() as cw:
cw.set('core', 'bare', False)
repo = git.Repo(clonedir)
repo.head.reset('--hard')
@vocx:
That may be too hard for an average user like myself.
It's a fair request.. I made a rudimentary PR to the BIM WB for this but @yorik thinks it should be implemented in a way that is gives the enduser more options (which makes more sense). See https://github.com/yorikvanhavre/BIM_Workbench/pull/30 basically lifted from the A2+ WB which shows the version number in the WB dropdown menu.
But @vocx makes a better point that we could use git to actually tell us the commit hash we have installed which could also be useful.
See this thread check workbench update with AddonManager
It seems at the moment each addon developer could implement a function to check the version of their own addon. But if the proper functions are moved to the Addon Manager, then this could work for all addons. It's probably only a matter of time until it's implemented. Just remind Yorik about it.
