I noticed that when I copy a window with draft.Move copy=true, the copy has an empty WindowParts array.
Mind you, when I do a edit-> duplicate and move that duplicate (make sure 'copy' is unchecked), all is fine.
S
Draft.Move copy=true on a window removes WindowParts array(fyi)
Re: Draft.Move copy=true on a window removes WindowParts array(fyi)
Wait, am I the only one experiencing this ?
- insert a window in the scene (not necessarily in wall),
- copy it with the Draft copy tool
Aaaaand it's gone (the copy that is).
If you inspect the copy, you'll notice all the components are gone.
Copying windows is a pain for me, am I doing something iffy ? I
Confirmed.
This issue seems to be related:
https://forum.freecadweb.org/viewtopic. ... 73#p326373
OS: Windows 8.1 (6.3)
Version: 0.19.18024 (Git)
Hash: 9cc8f6eb666b0a0ae2dc256f7bc0beb8c987710c
Python version: 3.6.8
Qt version: 5.12.1
I can't test right now (crashing when adding a window, must investigate...), but this should be fixed in git commit 617e8b5f91
I can confirm that the "WindowParts array" issue is fixed.
Note that the copy of the window uses the same sketch as the original. Which is apparently a separate issue but definitely seems related to this one (already mentioned):
https://forum.freecadweb.org/viewtopic.php?f=23&t=38491
Version: 0.19.18504 (Git)
Hash: f66023a646db4b2502bb3637897443b3525ca3c7
Qt version: 5.12.1
