version: FreeCAD_0.19.19424_x64_Conda_Py3QT5-WinVS2015, and fc 0.18.4
os: win10x64
Summary:
In DraftWB, newly created wire use first point as position, newly created B-spline user zero as position. "Convert Wire to Bspline" treates them differently.
But when a Bspline gets a non-zero position, it turns out to be a "freak". "Convert" donnot know howto handle it correctly.
Reproduce 1:
1. In DraftWB, draw a wire (polyline) that first point away from zero point.
2. recursively operate the command: Convert wire to B-spline.
3. new wire from the second time using above command is located with a obvious offset from initial position.
Reprodue 2:
1. in DraftWb, draw a B-spline.
2. move it away from initial position with "Move" tool.
3. command "Convert Wire to Bspline"
ps.
Tested on 2020-03-13, this bug is removed from latest build:
FreeCAD_0.19.19758_x64_Conda_Py3QT5-WinVS2015
[Solved] 0.19pre, DraftWB, weird when Convert wire to B-spline
Re: 0.19pre, DraftWB, wierd when Convert wire to B-spline
Attached are two updated Python files for you to test. I've tried them on the two builds:
OS: Windows 7 SP 1 (6.1)
Version: 0.19.19424 (Git)
Hash: 899854ac5d643e991a1006ed75aeff93baf3d224
Python version: 3.6.8
Qt version: 5.12.1
and
Version: 0.19.19503 (Git)
Hash: bb189d540cb958e63af44347a244188fae217e93
Qt version: 5.12.1
The crux of the bug surrounds the makeWire function being triggered from two scenarios, points by Gui interaction and those from a command. In DraftTools.py I've changed approx. line 4491 from:
to:
In Draft.py around line 362 I've changed it from:
to:
It will need some serious testing to ensure there aren't regressions caused in other areas.
Qt version: 5.12.1
and
Qt version: 5.12.1
elif (Draft.getType(self.obj) == 'BSpline'):
n = Draft.makeWire(self.Points, self.closed, self.pl)
if n:
self.bs2wire = True
n = Draft.makeWire(self.Points, self.closed, self.pl, None, None, self.bs2wire)
if n:
def makeWire(pointslist,closed=False,placement=None,face=None,support=None):
"""makeWire(pointslist,[closed],[placement]): Creates a Wire object
from the given list of vectors. If closed is True or first
and last points are identical, the wire is closed. If face is
true (and wire is closed), the wire will appear filled. Instead of
a pointslist, you can also pass a Part Wire."""
if not FreeCAD.ActiveDocument:
FreeCAD.Console.PrintError("No active document. Aborting\n")
return
import DraftGeomUtils, Part
if not isinstance(pointslist,list):
e = pointslist.Wires[0].Edges
pointslist = Part.Wire(Part.__sortEdges__(e))
nlist = []
for v in pointslist.Vertexes:
nlist.append(v.Point)
if DraftGeomUtils.isReallyClosed(pointslist):
closed = True
pointslist = nlist
if len(pointslist) == 0:
print("Invalid input points: ",pointslist)
# print(pointslist)
# print(closed)
if placement:
typecheck([(placement,FreeCAD.Placement)], "makeWire")
ipl = placement.inverse()
pointslist = [ipl.multVec(p) for p in pointslist]
if len(pointslist) == 2: fname = "Line"
def makeWire(pointslist,closed=False,placement=None,face=None,support=None,bs2wire=False):
return
nlist = []
closed = True
pointslist = nlist
# print(pointslist)
# print(closed)
if placement:
if bs2wire is not True:
- DraftTools.py
- (256.68 KiB) Downloaded 27 times
- Draft.py
- (289.44 KiB) Downloaded 45 times
Thank you, Syres,
I tested you fix on my machine, it worked well.
Hope no regresssion would happen, and I will keep eyes open.
No regression found on my machine till now.
Hope this fix be tested by more people, and merged into master branch early.
version: FreeCAD_0.19.19510_x64_LP_12.1.2_PY3QT5-WinVS2015
os: win10 x64
Re: 0.19pre, DraftWB, weird when Convert wire to B-spline
Above fix failed on recent build:
FreeCAD_0.19.19697_x64_Conda_Py3QT5-WinVS2015
Obviously just copying the two files I posted back on Feb 7th will no longer work but the specific changes quoted are still correct taking into account the line numbers are slightly different in Draft.py. I'll submit a PR by Friday night GMT hopefully when I've got a build that's very close to master to make sure everything is still fine.
As promised, PR has been submitted https://github.com/FreeCAD/FreeCAD/pull/3115 after re-test using:
Version: 0.19.19747 (Git)
Hash: 8533527af90d58ec5cd0c6e1a2477ca224022874
Qt version: 5.12.1
Qt version: 5.12.1
Well done, thank you.Syres wrote: ↑Fri Feb 28, 2020 10:55 am As promised, PR has been submitted https://github.com/FreeCAD/FreeCAD/pull/3115 after re-test using:
Qt version: 5.12.1
Re: [PULLED] 0.19pre, DraftWB, weird when Convert wire to B-spline
I completely appreciate English may not be your mother tongue but [PULLED] in England means Removed, Deleted or No Longer Available. Might be best to just have [PR Submitted] as the start of the thread title for the time being.
