Don't know what I did. The top view looks like this now. The grid has an angle.
Only after deleting AppData/Roaming/FreeCAD, then it back to normal.
Regards,
John
Arch: Set Grid Spacing to 1000mm causes Top view abnormal
Re: Arch: Top view abnormal
Not sure if below works ...
Set / reset the current Draft Working Place by clicking the button
(In Draft WB..)
Click Grid again
(In Draft WB..)
Click Grid again
Which button?
It seems when I set Grid Spacing to 1000mm, this problem comes up.
The button is displayed when in Arch WB.
Works Sometimes. But when you open a new document, the grid display still wrong.
