BIM Workbench?
BIM Workbench?
I'm an architect but a new user of FreeCad. I'm keen to work on the BIM workbench but cannot get my Addon manager to work.. The only workbench identified in my workbenches is 3DFindIT. (I only uploaded FreeCad yesterday). Is the BIM workbench still an add-on? There was talk about it being merged with the Archi workbench.. I've just found a work-around - Thanks Joko Engineeringhelp!
Re: BIM Workbench?
Welcome, please check IMPORTANT: Please read first before asking for help .An:a-ray wrote: ↑Sun Nov 22, 2020 10:31 pm I'm an architect but a new user of FreeCad. I'm keen to work on the BIM workbench but cannot get my Addon manager to work.. The only workbench identified in my workbenches is 3DFindIT. (I only uploaded FreeCad yesterday). Is the BIM workbench still an add-on? There was talk about it being merged with the Archi workbench.. I've just found a work-around - Thanks Joko Engineeringhelp!
Post your version of FreeCAD and describe the steps you drop into problem, and help the developer to fix it.
BIM add-on should be working
BTW, try version 0.19 pre-release version as it will be released with tons of new release and bug fixed.
Thanks.
Re: BIM Workbench?
Hi Paulee - thanks. Re pre-release 0.19 - I have downloaded the zip for 0.19 but as Im not hugely tech-savvy (yet?), dont know how to install it! Help again?
Re: BIM Workbench?
Update: Sadly Jokoengineeringhelp work around did not work for me so still no BIMWorkbench and struggling a bit with uploading FreeCAD-0.19. I have the FreeCAD-0.19_pre zip file, 7.z, extracted but no bin file and cant find exe
Re: BIM Workbench?
Since you haven't followed the posting guidelines in the ^^Big Pink Banner^^ at the top of the page, Your OS is unknown.
I suspect you are using windows if so from the download page:-
- Download https://www.7-zip.org/
- Download the FreeCAD_0.19.*-Win-Conda_vc14.x-x86_64.7z file from the release page
- Extract the binary from the .7z
- Run the FreeCAD.exe file to be found in the bin folder.
Re: BIM Workbench?
Bance should have given you the required procedure.
Good luck.
Good luck.
Re: BIM Workbench?
why BIM workbench is not an official tool inside FreeCAD? this probably is the most relevant
Re: BIM Workbench?
Depends heavily on what you are modeling. There are very different application fields for FreeCAD. The modular structure enables users to choose the tools they need.
Re: BIM Workbench?
And BIM module as an Add-on, as @Yorik indicated, has advatage of quick updating from time to time without the need to wait for official FC release.
Re: BIM Workbench?
There is a technical side in this and something I would call a management side. On the technical side there are addons which have to be downloaded separately. On the management side we may create something like an "Official Addon Repository". The difference would be, that the development of the core system could/should/must respect the official addons.
