With any text.
OS: Windows 10 (10.0)
Version: 0.19.22900 (Git)
Hash: b7b4250b7fe5e98bcdbe2a7c7be256132b35cd3d
Python version: 3.6.8
Qt version: 5.12.1
[Solved] Draft/Annotation/Text crashed FC
Re: Draft/Annotation/Text crashed FC
No problem here. Please add a step by step description of what you have done. You can also try to reset the configuration with the button in the preferences. Another possibility is to delete your config files or to move them in case you want to restore them.
OS: macOS 10.15
Version: 0.19.23058 (Git)
Hash: 6e60870ebcb2df018adb7a1281c00dde87750f11
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
OS: macOS 10.15
Qt version: 5.12.5
OCC version: 7.4.0
Done the reset.
Just Start FC, New doc, change to Draft, Annotation/Text, then crash.
There is a message sometimes.
That's how I did it. I have seen here Access violation issues before. Many, if not most, were related to graphics card/driver issues. Some of them are listed in the Known OS specific issues.
I once have this message due to my code array indexing error.
Since Annotation/Lable works, so maybe there is some logical error in the Annotation/Text code.
No crash for me either... But indeed we've seen this before.
Do other Draft tools (line, rectangle...) work?
No, just switch to Draft and it crashs.
I found under my AppData/Roaming/FreeCAD folder, there is a crash.log file. Part of it is:
Log: Id: 6468: D:\FreeCAD_0.19.21937_x64_LP_12.1.6_PY3QT5-WinVS2015\lib\PartGui.pyd:PartGui.pyd (00007FFEFB780000), size: 3248128 (result: 0), SymType: '-exported-', PDB: 'D:\FreeCAD_0.19.21937_x64_LP_12.1.6_PY3QT5-WinVS2015\lib\PartGui.pyd'
Log: Id: 6468: D:\Program Files\Graphviz 2.44.1\bin\fontconfig.DLL:fontconfig.DLL (0000000180000000), size: 856064 (result: 0), SymType: '-exported-', PDB: 'D:\Program Files\Graphviz 2.44.1\bin\fontconfig.DLL'
Log: Id: 6468: D:\Program Files\Graphviz 2.44.1\bin\expat.dll:expat.dll (00007FFEFB740000), size: 204800 (result: 0), SymType: '-exported-', PDB: 'D:\Program Files\Graphviz 2.44.1\bin\expat.dll'
Log: Id: 6468: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFF504DB38D)
Log: Id: 6468: 00007FFF504DB38D (ntdll): (filename not available): RtlEnterCriticalSection
Log: Id: 6468: ERROR: SymGetLineFromAddr64, GetLastError: 487 (Address: 00007FFF4E171D15)
Log: Id: 6468: 00007FFF4E171D15 (KERNELBASE): (filename not available): FindNextFileW
Graphviz is needed for the Dependency Graph.
Re: [Solved] Draft/Annotation/Text crashed FC
Details are in Dependency Graph wiki page
I have a solution that doesn't involve removing GraphViz here. The upshot is that you only need to replace the fontconfig.dll that comes with GraphViz.
