Active working plane changes when I close Draft Edit panel
1) Working Plane "Fundaciones" is active.
2) Select Rectangle002 object.
3) Double click on Rectangle002 object or Draft Edit command for Rectangle002
4) Click on close button in the panel task.
5) The working plane active will change to another working plane (Floor002).
Is this an expected behavior?
OS: Windows 10 (10.0)
Version: 0.19.23578 (Git)
Hash: 50c3cbf00579dc4941ca743c25720d016b0453ce
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
[Fixed]Active working plane changes when I close Draft Edit panel
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Re: Active working plane changes when I close Draft Edit panel
Ill have a look ASAP!
this is not the normal when "automatic" is activated in the working plane setup?
Nop. In this case, the active working plane changes to another working plane. Not to the aligned view. Also, you can see in the gif the working plane button at the top. It shows the same working plane without variation.jtm2020hyo wrote: ↑Tue Jan 19, 2021 5:13 pm this is not the normal when "automatic" is activated in the working plane setup?
::bitacovir::
Should I add this bug to the Bugtracker?
::bitacovir::
yes, please. you can assing it to me!
::bitacovir::
I assigned it to carlopav. Thanks for working on it.
Hope to be able to do it before the release
there is a pull request fot this bug: https://github.com/FreeCAD/FreeCAD/pull/4492
